It is currently Tue May 12, 2026 1:19 am
 Post subject: Oil Change Tips...
PostPosted: Sun Mar 03, 2013 4:50 pm
Tips or tricks for oil changes? Filter will not catch oil tube threads, oil tube will not catch oil pump. Had the filter jump off and lost 3 quarts.
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
 Post subject: What filter number?
PostPosted: Sun Mar 03, 2013 5:25 pm
What filter part number are you using?
PostPosted: Sun Mar 03, 2013 5:41 pm
K&N HP-3001, just becuase I haven't looked up which others also fit. I will be ordering a case of WIX filters soon.
PostPosted: Sat Mar 09, 2013 6:32 pm
Car Model: 75valiant custom
i've had better luck with the house brands than the name brands. i think filter manufacturers have gotten all caught up in the "cheap price" frenzy that pays no mind to quality.
 Post subject: Lol...
PostPosted: Sat Mar 09, 2013 7:20 pm
When you pulled your old filter off did the original oil filter gasket remain on the pump flange? (That's the only way I could think of that the filter would not seat and catch the threads on install.)
-D.idiot
PostPosted: Sat Mar 09, 2013 9:35 pm
How tight was the old filter you pulled off? Some bastard might of over tightened it with a band wrench and ruined the threads.
70 Plymouth Valiant 4dr
PostPosted: Sat Mar 09, 2013 9:37 pm
Get a new stand pipe if you have to....
PostPosted: Sun Mar 10, 2013 3:27 pm
Well the threads on the pipe catch the filter but never the pump housing. The filter jumped off the pump. Anyway to prevent this or reduce the chance of this happening?
PostPosted: Sun Mar 10, 2013 5:11 pm
6 Pack Dart
Does the stand pipe screw onto the pump snugly? You screw the filter on after the pipe is tight on the pump.
Richard
PostPosted: Sun Mar 10, 2013 7:38 pm
I've been trying to avoid putting the filter on after putting the pipe on the pump because I get some nasty scraping noises after oil changes and when the car sits for a while, then the engine settles into a nice ticking idle.
PostPosted: Sun Mar 10, 2013 7:47 pm
6 Pack Dart
You just have explained why the pipe will not stay in your pump, it is going the path of least resistance UP INTO THE FILTER.
Richard
PostPosted: Sun Mar 10, 2013 8:29 pm
It stays on... just won't catch the threads on oil pump if I try to install it with the filter on.
PostPosted: Sun Mar 10, 2013 10:31 pm
You need to install the pipe into the pump. It should not be removed. Then install the filter on the pipe/pump.
Users browsing this forum: Bing [Bot], Google [Bot] and 10 guests
