It is currently Mon Jan 13, 2025 9:09 am
 Post subject: Tachometers
PostPosted: Tue Mar 12, 2013 1:39 pm
Does anyone know where I can get a quality external engine Tachometer for setting idle speeds and tracking engine speed?
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
PostPosted: Tue Mar 12, 2013 2:35 pm
Autocorrect, lol. I just use a timing light with a built-in tach when I'm working under the hood.
But if you do find a good engine Rachel, ask her if she's got a sister.
Escape Velocity Racing
PostPosted: Tue Mar 12, 2013 3:27 pm
Wow! Oops! If I've ever felt like an idiot, now is the time. I must have been auto correct :P Substitute: Tachometer
 Post subject: Yep..
PostPosted: Tue Mar 12, 2013 4:49 pm
If you plunk the $100 for a craftmans digital dialback timing light it has a button that goes from advance to rpm right at your thumb...
PostPosted: Tue Mar 12, 2013 4:56 pm
Hmm I'll check it out. Sounds cool :)
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot], karl wagenbrenner, Semrush [Bot] and 5 guests
