| Quick Time bell housing https://slantsix.org/forum/viewtopic.php?t=51398 |
| Author: | 65CrewCabPW [ Wed Mar 13, 2013 10:11 am ] |
| Post subject: | Quick Time bell housing |
The catalog for this ( rm 7072 ) says you can use an 11 inch clutch. And it has the high starter location. My interest is using this in a truck ( 4x4 ) and I want a stout clutch. It says it uses a 122 tooth flywheel, which seems to be the smaller one. I thought you couldn't use the 11 in clutch with the smaller flywheel. Can someone clue me in here? I want to bolt an NV2500 to it (apparently, the bottom bolts match, the top ones are offset a little). Can you really use a larger clutch with this bellhousing, than you can with the OD truck bellhousing? |
| Author: | Joshie225 [ Wed Mar 13, 2013 12:11 pm ] |
The clutch information is wrong. Small flywheel only and therefore a small clutch. |
| Author: | 65CrewCabPW [ Wed Mar 13, 2013 12:19 pm ] |
Figures. Thanks. I might as well just use a Junkyard aluminum housing, and have someone fill and redrill and tap it for an NV2500, then. |
