| Copper Head Gaskets https://slantsix.org/forum/viewtopic.php?t=5140 |
| Author: | Tom Drake [ Tue Mar 04, 2003 5:28 am ] |
| Post subject: | Copper Head Gaskets |
Copper head gaskets for a slant 6 on the shelf! http://www.scegaskets.com/domesticResul ... ition=PAR: |
| Author: | Doctor Dodge [ Tue Mar 04, 2003 8:24 pm ] |
Wow, in 6 different thicknesses from .032 to .098 Now that is cool! DD |
| Author: | Patrick Devlin [ Tue Mar 04, 2003 9:44 pm ] |
I can only say one thing (after o-ringing the block). TURBO TIME! |
| Author: | Tom Drake [ Wed Mar 05, 2003 4:12 am ] |
Now you know why I posted it! |
| Author: | Jim Cox [ Thu Apr 17, 2003 9:08 pm ] |
Cox Bros is a distributor for SCE and can supply any copper gasket you would require and can sell cheaper than buying direct. SCE like all other major parts suppliers will not under sell their distributors. Cox Bros is the most competitive one stop shop for performance slant six parts in the country. Please call or e-mail for a parts flyer (614-268-9920). |
| Author: | shiftless [ Fri Aug 15, 2003 2:26 pm ] |
You shouldn't need a copper head gasket for forced induction. The head gasket acts as a safety measure. If you're blowing head gaskets, something is wrong with your tuning (running too lean, detonating, etc) and the blown head gasket will alert you to that fact. A standard Felpro blue gasket should hold up fine on a properly tuned engine, especially one with such a wide gasket and with such low boost levels (15 psi or less). I'd rather replace a head gasket than a few pistons. |
| Author: | MikeChilando [ Tue Nov 24, 2009 6:27 am ] |
| Post subject: | O Ring tool for block |
Anybody got a o ring tool , hopefully Isky, that you want to sell. ? I also want a couple of junk 225 heads to cut up for porting profiles. I still need a 225 block or 2 ... Iron, not aluminum . Somewhere close to Nashville TN my e mail is Alkydigger@yahoo.com mike 615-483-6830 |
| Author: | Shaker223 [ Tue Nov 24, 2009 8:17 am ] |
Isky still has the tool and Hussy has copper head gaskets as well. There was a group buy earlier this year. |
