| will a dakota bell bolt to a /6 https://slantsix.org/forum/viewtopic.php?t=51412 |
| Author: | giezy [ Thu Mar 14, 2013 10:18 pm ] |
| Post subject: | will a dakota bell bolt to a /6 |
what are the differences with the two? starter location? bolt pattern? would like to use a r154 5 speed |
| Author: | DusterIdiot [ Thu Mar 14, 2013 11:22 pm ] |
| Post subject: | What engine? |
Mopar standardized their bellhousing bolt pattern to the ever famous "LA" small block pattern (273,318,340,360,3.9,5.2,5.9,8L) so if you have a 3.9L or 5.2L equipped Dakota you then will need to get the famous adaptor plate from a mid-late 60's truck that was equipped with a slant six and A-727, or be on the lookout for one of the AREngineering adaptor plates that were made (can be used with A-904 style tranny/A-500 with a little elbow grease), or you can look at the some of the other bellhousing/adaptor posts and see what else is being done...maybe the tranny bolt pattern is enough to allow you to modify one of the standard slant six bellhousings to the tranny with a little welding and machine work (IE similar to the T-5 bellhousing group buy). -D.idiot |
| Author: | 65CrewCabPW [ Sat Mar 16, 2013 11:40 pm ] |
| Post subject: | Re: will a dakota bell bolt to a /6 |
Quote: what are the differences with the two? starter location? bolt pattern?
There's no bell housing that comes anywhere near fitting a slant six that can bolts to the circular pattern on that trans. I believe that trans is a near match for the AX-15.
| Author: | giezy [ Sun Mar 17, 2013 10:09 am ] |
ax15 hass the same bolt pattern as the r154 to the bell |
