It is currently Sat Nov 28, 2026 4:51 am
 Post subject: Main caps..one missing.
PostPosted: Mon Jun 24, 2013 11:36 am
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
I have a 198 block that I'd like to build up. Problem is that the engine was tore apart years ago and during our recent move, one of the main caps turned up missing. I have 1-2-3 and no 4th.
Can I rob the #4 main cap from a 225 and use that? Or would that mean an expensive line bore job??
Or should I just take a 225 apart and start from scratch. I wanted to use the 198 block because it seems to be the nicest one I have and it is the very rigid "BH" casting. It also had a small weight advantage over the last 225 block I weighed.
Opinions please...thanks.
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Mon Jun 24, 2013 12:16 pm
The only way to "save" your 'lost cap" block is to find a few extra SL6 main caps and test fit them to the block, to see if you can find one that matches the current main bore line.
The goal is to get within a thousands or two so a "align-hone" job will clean-up any mis-match.
Lucky for you... I have saved many SL6 main caps over the years... for this exact reason.
Send me a PM and we can work-out details to ship you all the #4 caps I have... with the hope that one will work-out.
In general... this is a time comsuming and somewhat expensive approach. (aline - honing starts around $100.00 in my area)
A different block may-be a cheaper / faster solution.
PostPosted: Mon Jun 24, 2013 12:34 pm
How much overbore and how much HP are you looking to make on this block? If 0.1" or less over and <450 HP or so, then I would just use the 225 block, if that's in decent shape. Of course the BH block can apparently be bore larger and it would be nice to save that block too.
PostPosted: Mon Jun 24, 2013 1:47 pm
Lou,
Naturally aspirated build. I *hope* to have 220hp or so in a light weight vehicle. 11:5:1 -12 targeted compression. I hope the goal is realistic.
I have been removing weight out of the car because it's cheap to do so, only cost me time :lol: .100 over is where I want to be.
I have the cam, head cut .110 (getting o/s valves) ported, intake, headers, crank scraper and some other items.
I would do a cast crank motor but all my rebuild parts are for forged crank engine.
Doc,
Thanks for the input. I also have a 225 with the numbers 2806830-3 followed by a "U". I know that means it has a forged crank but not sure about the "U" code or application. I was thinking years ago that I pulled a bracket off of this engine that stated "Industrial". Factory to this engine?? who knows :lol: It is all there though...
