spark plugs?
https://slantsix.org/forum/viewtopic.php?t=51418
Author:  slant6 [ Fri Mar 15, 2013 6:38 pm ]
Post subject:  spark plugs?
Any recommendations on plugs for my stock 225? Tia, Dana
Author:  emsvitil [ Fri Mar 15, 2013 6:48 pm ]
drool tube or peanut head?
Author:  duval67 [ Fri Mar 15, 2013 7:22 pm ]
I've heard good things about the NGK UR4 for the later heads. I'm using them now and am seeing good performance
Author:  ILMopars [ Fri Mar 15, 2013 7:48 pm ]
Champion RN12YC
Autolite 65 or 66
Be careful between GM, Ford, and Mopar OE spark plug manufacturers. The heat ranges are similar but not exact from each brand. Some may fill the gaps between the plugs from one mfg to the next.
Author:  DusterIdiot [ Fri Mar 15, 2013 8:21 pm ]
Post subject:  Most popular
I would go for the NGK ZFR-5N on a stockish pre 1975 slant six...
If a 1975-1987 slant six then the NGK UR-5 is the stock plug, and UR-4 is better/hotter if you have an oil burner or a slant with rich A/F mix problems.
-D.idiot
Author:  Chuck [ Thu Jun 20, 2013 10:26 am ]
I bought the ZFR-5N plugs and then saw that they are about 1/4" longer than the stock plug! Why is that? Should I use the GR4 instead?
Author:  DusterIdiot [ Thu Jun 20, 2013 11:11 am ]
Post subject:  It's...
The GR-4 would be fine for stock use. The ZFRN is for the AMC/Jeep head and for the modern Dodge Magnum engines. The real difference is the reach on the electrode, this puts the ignition kernel closer to the center of the chamber and the electrode is more exposed to the mix, allowing the flame front in a stocker engine to burn the mix more uniformly then being biased to one side.
In effect it would be similar to using the stock plug and setting your static timing about 5 degrees more advanced getting the leg up on the not so efficient "carburated" mix in the cylinder, but with the electrode in the center you don't have the delay of the flame front taking the milliseconds to get there (which would be regulated by a distributor spring change...).
I've run these in my drool tube heads with no issues (actually run better than the stocker plugs), the only advisement would be that as you approach cutting the head or deck for say about 10:1 SCR the extended electrode may impact the piston so a test fit needs to be used (most people running hi-po engines will be running a stock cooler plug anyway to resist detonation.
It's really a personal choice on using the plugs or not, but when Dan gave us this option he opened up a great opportunity to help overcome the typical issues of the 40-50 year old carburated system with a simple upgrade.
2 cents,
Author:  Chuck [ Fri Jun 21, 2013 11:48 am ]
Thanks D. Dan S. sent me some info too. Unfortunately, I don't know if the head I recently installed has been shaved or not. I got it from the estate of a fellow slixer (Ken Orr) who recently passed away, and it had already been redone. I don't know if there will be a problem with the piston clearance. I used to have a head on my convertible that had been shaved 75 thou., so I know it is possible that Ken did something with this one. I'll have to make sure that there is not a clearance problem before I use them.
Author:  DusterIdiot [ Fri Jun 21, 2013 12:15 pm ]
Post subject:  No problem
.075 shouldn't be a deal breaker for these, I'd worry if the total cut deck+block =.150 or so...
You can always buy a cheap autolite 985, install it and see if it binds up rolling the engine over by hand... :wink:
-D.idiot
Author:  Chuck [ Mon Jun 24, 2013 3:44 pm ]
Post subject:  Re: No problem
-D.idiot
OK, thanks.
