| double roller timing set https://slantsix.org/forum/viewtopic.php?t=5155 |
Page 1 of 2 |
| Author: | wdethtrip [ Wed Mar 05, 2003 12:13 pm ] |
| Post subject: | double roller timing set |
If anyone needs a double roller timing set for a /six, Clifford Performance just started carring them. It's not on the web site, you have to call them about it. With shipping and taxes, it came out to be just above $150.00 for me here in southeast Missouri. |
| Author: | Doc [ Wed Mar 05, 2003 2:28 pm ] |
The Cox Boys are also carring double row, roller timing sets, last I checked they had two kinds, the iron one and the multi keyed steel ones from JP Performance. DD |
| Author: | Slant Cecil [ Wed Mar 05, 2003 3:02 pm ] |
The iron set is $60, the steel set is $98. Cecil |
| Author: | slantzilla [ Wed Mar 05, 2003 7:59 pm ] |
Guess Clifford's gotta make up all the cash their losing from discounting the Hyper-Pak intakes, huh? |
| Author: | wdethtrip [ Tue Mar 11, 2003 11:17 am ] |
I tried calling Cox Brothers, but kept on getting fax machine noises. |
| Author: | Slant Cecil [ Tue Mar 11, 2003 12:33 pm ] |
The fax and phone #s are close. Fax # is 614-268-9930 Phone # is 614-268-9920 It was working last week. Cecil |
| Author: | NCDart [ Wed Mar 12, 2003 5:10 am ] |
| Post subject: | Does mopar still carry the roller timer chain kit? |
I was looking at the D.C. Connection info and it said you need these items to convert to a roller chain. Is this true? Still Available?
Joe |
| Author: | Dart270 [ Wed Mar 12, 2003 6:12 am ] |
All you need to do is buy the Cox Bros set, that is the conversion. happy building, Lou |
| Author: | Jopapa [ Wed Mar 12, 2003 3:15 pm ] |
What's the difference between different timing sets? I had thought there was just chain type and gear type timing sets. Someone care to enlighten me? |
| Author: | DusterIdiot [ Wed Mar 12, 2003 6:13 pm ] |
| Post subject: | Silent Chain vs. Roller Chain |
Silent Chain is the normal set you pick-up for a standard driver/rebuild it has two sprockets (OEM ones are nylon, new Melling ones are Iron...) and a multilayered.linked chain with thin slots...it tends to wear-out and stretch after some use and shifts your timing or plays merry heck with it when it does go. The silent chain doesn't lend itself too well to being 'bushed' if you're degreeing your camshaft... A double roller chain on the other hand.... ![]() Is a nice improvement (supposedly is standard on all 'magnum' V-8's), it sometimes has 'key ways to reset your timing if the cam won't degree properly, you can also drill the cam gear and bush it to reset the timing events (mopar bushing set, or some lead shot...), the roller chain I also hear keeps timing pretty steady (so far 10k on my rebuild and my timing mark is still where it was 9800 miles ago...) someone else might have a better way to compare these fuji apples to golden delicious... ![]() ![]() -D.Idiot |
| Author: | Doc [ Thu Mar 13, 2003 10:16 am ] |
The term "roller chain" comes from the small roller sleeves and axle pins used in this type of chain. The sleeves actually roll over the gear tooth. As for the gears, material and construction are different. Plastic coated aluminum, cast iron and steel gears are all offered. the heat treated and multi-keyed bottom gear (crank gear) really helps if you degree-in the cam. DD |
| Author: | Jopapa [ Thu Mar 13, 2003 11:05 pm ] |
Quote: the heat treated and multi-keyed bottom gear (crank gear) really helps if you degree-in the cam.
What exactly does it mean when you degree-in the cam?DD Note the change of sig to reflect the obvious |
| Author: | Doctor Dodge [ Thu Mar 13, 2003 11:40 pm ] |
To "Degree-in" a cam is to set the position of the cam in relationship to the crankshaft and pistons. The timing chain and gears connect the crank movement to the cam "events" so the valves open and close at the right time. Search the messages for "degree wheel' or "split overlap" for more info. DD |
| Author: | cycledog [ Fri Mar 14, 2003 6:21 pm ] |
| Post subject: | Cox Brothers |
I ordered a steel timing set from Cox today. The lady I talked with, I think her name is Rachel, was very pleasent and helpful. If she is any indication of the way these folks are I will look forward to doing more business with them. C-Dog |
| Author: | Doctor Dodge [ Tue Mar 18, 2003 11:05 pm ] |
I may as well add a photo of the JP Performance timing chain set. All steel gears with multi keyways on a heat treated lower gear. It is a true roller type chain. Cox has these imported from down under, they are made in australia. DD
| Page 1 of 2 | All times are UTC-07:00 |
