| Broken Ignition and Shift Lever. https://slantsix.org/forum/viewtopic.php?t=51558 |
| Author: | nicholas482109 [ Fri Mar 29, 2013 1:57 pm ] |
| Post subject: | Broken Ignition and Shift Lever. |
I got to my car this morning to find some someone had tried to steal my car. I found a 20 lb dumbbell sitting on my passenger seat, a broken pocket knife, a broken screw driver, my inside mirror smashed, pieces of my ignition switch on the floor and my shift lever snapped off! I guess I'm lucky the idiot was unsuccessful but was still left with some damage to the car, making it undrivable. The ignition lock cylinder needs to be replaced, that I already bought but I cannot figure out how to remove the old one. I got a steering wheel puller but with out being the electrical portion of my factory manual, I'm thoroughly confused. If anyone could take a look at the pictures below and give me some instruction how to remove it, I would very grateful. I need to get the car out of the place it's parked now. ![]() ![]() I think I need to remove the screw in top right, and stick a small screw driver down that hole but I can't grip the cylinder in anyway to pull it out. |
| Author: | Supercharged SL6 [ Fri Mar 29, 2013 5:39 pm ] |
I think you need to remove the turn signal switch & top housing on steering column, then there should be a screw that holds ign. cyl. in place than you can use a screw driver to pry it out from the inside |
| Author: | matv91 [ Fri Mar 29, 2013 6:20 pm ] |
If you have the 1978 chasis-body service manual. Look at section 19 page 30 . Ignition key,lock and switch removal covered there. Not in electrical section. |
| Author: | nicholas482109 [ Sun Mar 31, 2013 1:49 am ] |
Quote: If you have the 1978 chasis-body service manual. Look at section 19 page 30 . Ignition key,lock and switch removal covered there. Not in electrical section.
Thanks, that is perfect. Should have it good to go by Monday.
| Author: | Kidd [ Sun Mar 31, 2013 8:13 am ] |
If stuff is broken, and you need a column, let me know.I have a column out a 71 dart with a key, and a shifter....sell it cheap.No idea of the shipping though. |
