It is currently Sat Nov 28, 2026 2:40 am
 Post subject: Distributor Wrench
PostPosted: Tue Jun 25, 2013 12:03 pm
I am having a bear or a time finding the 7/16" distributor wrench. Anyone help direct me?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
 Post subject: Lol..
PostPosted: Tue Jun 25, 2013 12:23 pm
You can always do it like my grandfather...get a long handled 7/16" wrench (HF cheap would work), have a buddy heat the handle 2" from the end of the wrench with an oxy-acet torch , bend in vise 90 degrees and dip in bucket of water....
PostPosted: Tue Jun 25, 2013 12:28 pm
May have to. None of the local shops have it. I found one on ebag but it doesn't end for a week and I would really like to go a little faster.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Tue Jun 25, 2013 12:36 pm
Car Model: 1964 Valiant V200
I got all mine at swap meets. Snap-on might still make one but it would be expensive.
PostPosted: Tue Jun 25, 2013 2:53 pm
crows foot, swivel and an extra long extension works well.
1964 Dart GT
PostPosted: Tue Jun 25, 2013 3:44 pm
i got mine at Napa a few years back, but I never use it on a slant. I just use a socket on a long extension on the slant six. If you get the distributor set correctly in relation to the cam, then you never need to touch the second adjustment bolt on the bottom of the distributor. If you get too far in one direction just pull the distributor, jump a tooth in the right direction, and reinstall the distributor .
PostPosted: Wed Jun 26, 2013 4:12 pm
Reed you were right I got the RPM's down to about 700 and it ran not real smooth but I think my cam has to do with the stumble. The Vacuum is bounces between 28-30 and the timing is about 12-14 degrees. Hard to tell since the marks on the tab can't be used. Sum b#tch machinist.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
 Post subject: Yep...
PostPosted: Wed Jun 26, 2013 5:43 pm
With a cam at 230 @.050 it will have a little lump and you give up a couple inches of vacuum even if you asked for a wider LSA to limit the overlap value. Because of this low idle is limited, you may need to dial down to about 850 rpm to keep it in check especially if you have an automatic (this is because higher duration cams generally make more power in the midrange and higher rpm and sacrifice at low rpms...some of this can be made up by using more compression and/or using a manifold that improves low end performance, as well as calculating and dialing some advance into the cam's timing.
You will probably get a little more control when you switch to EI. 28-30"Hg is pretty good for vacuum, although that's a pretty high reading, typically this cam would be in the 19-21" range...+/-
PostPosted: Wed Jun 26, 2013 7:16 pm
If I brought the vacuum back to around 20 it ran WAY worse and same thing when I got the vacuum higher. I figured I would have to increase the idle a little but I wanted to be able to take it out and around first.
I am still messing with the accelerator pedal and kickdown.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
 Post subject: Hmm..
PostPosted: Wed Jun 26, 2013 7:43 pm
What did they grind your lobe separation at on the cam card?
PostPosted: Wed Jun 26, 2013 8:37 pm
Lobe Separation: 108
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
