It is currently Sat May 09, 2026 3:15 am
PostPosted: Thu Apr 11, 2013 8:40 pm
I have to replace my gasket and was wondering what the best one for the slant is. Thanks for the input.
1967 Dart GT Super 6
 Post subject: Rubber...
PostPosted: Thu Apr 11, 2013 9:12 pm
Cork Gasket is OK, but after it's cooked in, it tends to self destruct if a relash is done. The Felpro or Corteco rubber gaskets seem to hold up better and as long as you clean up the mating surfaces should get you through quite a few valve lashes before being a real leaker.
PostPosted: Thu Apr 11, 2013 10:01 pm
I like the rubber ones.
Install (and re-install) with some white grease smeared on it and it comes right off without sticking...........
PostPosted: Fri Apr 12, 2013 3:32 am
Online
I haven't used any myself, but have heard good reports about these.
http://www.realgaskets.com/files/automo ... m#chrysler
PostPosted: Fri Apr 12, 2013 4:41 am
Realgaskets.com on my motor.
I like them.
Will
PostPosted: Fri Apr 12, 2013 9:18 am
thanks I just ordered one from real gaskets.
