| Flex plate fitment https://slantsix.org/forum/viewtopic.php?t=51678 |
| Author: | Otateral [ Wed Apr 10, 2013 9:59 pm ] |
| Post subject: | Flex plate fitment |
Ran into a problem with a mid-70s engine, which had an early crank put into it. It wouldn't fit my '69 904. I'm getting a custom torque converter made so that everything should fit. My question is the flex plate. It's one for the later engine/trans, so I believe it's slightly larger than the one for the early motors. Is this fine? I understand that if it was the other way around, it just wouldn't fit. But is a small gap between the crank and the flex plate ok? |
| Author: | DusterIdiot [ Thu Apr 11, 2013 6:52 am ] |
| Post subject: | I have... |
I think i have an early flex plate that I could let go for $5 = shipping if needed. I will check the morning. -D.Idiot |
| Author: | Otateral [ Thu Apr 11, 2013 4:10 pm ] |
Sure. This could be one of those things where the flexplate I have is fine, but I'm worried it will give me trouble after a few thousand miles. |
| Author: | DusterIdiot [ Thu Apr 11, 2013 4:45 pm ] |
| Post subject: | Yes. |
I have one pre-1968 "small hub" stock flex plate on my wall of 'spare stuff'. Let me know if you do need it. -rob |
