| What kind of valve cover gasket is the best? https://slantsix.org/forum/viewtopic.php?t=51690 |
| Author: | Smokin Jays [ Thu Apr 11, 2013 8:40 pm ] |
| Post subject: | What kind of valve cover gasket is the best? |
I have to replace my gasket and was wondering what the best one for the slant is. Thanks for the input. |
| Author: | DusterIdiot [ Thu Apr 11, 2013 9:12 pm ] |
| Post subject: | Rubber... |
Cork Gasket is OK, but after it's cooked in, it tends to self destruct if a relash is done. The Felpro or Corteco rubber gaskets seem to hold up better and as long as you clean up the mating surfaces should get you through quite a few valve lashes before being a real leaker. -D.Idiot |
| Author: | emsvitil [ Thu Apr 11, 2013 10:01 pm ] |
I like the rubber ones. Install (and re-install) with some white grease smeared on it and it comes right off without sticking........... |
| Author: | Charrlie_S [ Fri Apr 12, 2013 3:32 am ] |
I haven't used any myself, but have heard good reports about these. http://www.realgaskets.com/files/automo ... m#chrysler |
| Author: | Will [ Fri Apr 12, 2013 4:41 am ] |
Realgaskets.com on my motor. I like them. Will |
| Author: | Smokin Jays [ Fri Apr 12, 2013 9:18 am ] |
thanks I just ordered one from real gaskets. |
