It is currently Wed Nov 18, 2026 12:33 am
 Post subject: t5 to quicktime bell ??
PostPosted: Sun Mar 03, 2013 11:31 am
I am only seeing older posts on this is this avalible with the t5 bolt pattern and correct depth for slant six to ford t5 thanks. Also going to use hydraulic throw out bearing to simplify linkage thanks
1963 Plymouth Valiant Wagon
PostPosted: Wed Mar 06, 2013 7:29 pm
Anyone running it with a t5 thanks
PostPosted: Wed Mar 06, 2013 11:20 pm
The drawback to a Quicktime is that it uses the stock Slant clutch and flywheel. People spending that much money usually want to get away from those pieces.
PostPosted: Thu Mar 07, 2013 5:12 am
A few people have bought these, but I don't think anyone is running yet with a T5.
PostPosted: Thu Mar 07, 2013 12:41 pm
Car Model: Toad Wagon
I don't believe they've run'em for anything but Chrysler gearboxes as yet.
Though I haven't taken exact measurements, I do have to say that there looks to be room inside for a larger clutch package.
I'll have it out in a couple weeks (prepping for the season), and'll try to remember to get some numbers.
Sex, drags, and rock & roll.
Dick, 225% crazy.
PostPosted: Sun Apr 28, 2013 6:21 pm
Old6rodder any luck
PostPosted: Sun Apr 28, 2013 6:22 pm
Old6rodder any luck
PostPosted: Sun Apr 28, 2013 11:59 pm
Yeah, I had to pull the engine prior to going down to Barona for their Antique Drags last weekend. I took the opportunity to measure the inside of the QT /6 bell. If you want to download it you can click on this picture for the source at Flickr, which you can copy by bringing up the original, I make'em public.
In addition, the 13.25" ID could be massaged out at least another 1/4" with but a bit of angle grinding at the two heavy blocks.
Dick, 225% crazy.
PostPosted: Tue Apr 30, 2013 6:33 pm
Car Model: 1964 Valiant V200
Lakewood/quicktime does not make a bell for the slant six with a T5 bolt pattern. They DO make an off-the-shelf slant six bell with the regular Mopar 3 and 4-speed pattern. They CAN make one for the T5 but it will cost you $1090.
