It is currently Sun Nov 15, 2026 10:07 am
 Post subject: crossmember
PostPosted: Sat Apr 20, 2013 10:10 am
Poser
Getting ready to put the Demon together. Noticed the transmission mount needed replacing. Got to thinking. :shock: Will a 904 auto bolt in and line up to the crossmember that had the OD Manual? Does this take an entirely different crossmember piece? I would lay both trans side by side for an eyeball but both OD units are at A&A at the moment. Thanks for the advice.
PostPosted: Sat Apr 20, 2013 1:02 pm
I think they are the same. But I have been wrong before.
Rick
PostPosted: Sat Apr 20, 2013 1:27 pm
Just Check your measurments from Bellhousing with manual trans to Mounting pad and then repeat this same bell to pad measurement also on the 904.
Should be the same unless you are using a b/Ebody/ Truck trans in your car for some reason.
PostPosted: Sat Apr 20, 2013 1:59 pm
Same crossmember, same mount.
PostPosted: Sat Apr 20, 2013 2:38 pm
Poser
Thank you gents!
