| 69' Valiant Signet cruiser https://slantsix.org/forum/viewtopic.php?t=51768 |
| Author: | DusterIdiot [ Fri Apr 19, 2013 8:27 pm ] |
| Post subject: | Nice... |
Good lookin' Signet! Take a pic of your exhaust manifold (especially the choke pocket). I may have one from that year that would take care of that problem. I might also have a spare instrument cluster from my '67 signet that should fix your other gauge problems, knocking around my shop. -D.Idiot |
| Author: | valiant200kid [ Sun Apr 21, 2013 11:03 am ] |
i have a Valiant 200 identical too yours the only difference is i have body side moldings and blue interior. i also put 1971 valiant wheel covers on mine |
| Author: | SdSlant69 [ Sun Apr 21, 2013 7:28 pm ] |
Today I added a battery tie down. It's not perfect looking but functional. ![]() One thing at a time. |
| Author: | DusterIdiot [ Mon Apr 22, 2013 5:00 pm ] |
| Post subject: | That was a mixed bag... |
Well I have one with the open pocket left, and as you can see the bolts and stud are all broken off (oddly the choke flap is free and clear and all intact.) So no go there. I have a 1967 valiant circuit board that still has the factory blue film covering the copper traces, if you should find that your gauges are not working because the board has corroded. -D.Idiot |
| Author: | SdSlant69 [ Mon Apr 22, 2013 5:47 pm ] |
Thanks for trying on the manifold. I'll have to order a new from RockAuto or something (I'll be sure to verify that it is for my exact year). Not in a rush for this as my crack isn't too significant. Tearing apart the dash is daunting but I'm just gonna go for it next weekend. I just ordered a gas can in the meantime. |
| Author: | DusterIdiot [ Mon Apr 22, 2013 6:35 pm ] |
| Post subject: | Round 2... |
If you are going to order a new one, I'm sure they will be like the later versions with the closed choke pocket. I do know I have a couple of those in much better and useable shape. The problem there will be the choke thermostat and pull off...you would need the full electric conversion choke in any case, or if a Holley 1920 carb the now discontinued pull off for a 1973 225 slant six Valiant... -D.Idiot |
| Author: | SdSlant69 [ Tue Apr 23, 2013 5:30 pm ] |
What, if any, modifications need to be done to make a manifold with a closed choke pocket work my current set up? |
| Author: | DusterIdiot [ Tue Apr 23, 2013 5:32 pm ] |
| Post subject: | Just |
Quote: What, if any, modifications need to be done to make a manifold with a closed choke pocket work my current set up?
You would have to get a late choke pull off, yours will not work (I might have a used one that's intact laying around as well.-D.Idiot |
| Author: | valiant200kid [ Sat Apr 27, 2013 8:40 am ] |
my dash is cracked in the same places |
| Author: | Rick Covalt [ Mon Apr 29, 2013 3:12 am ] |
Valiant200kid, you have PM |
