| crossmember https://slantsix.org/forum/viewtopic.php?t=51774 |
| Author: | wvenable [ Sat Apr 20, 2013 10:10 am ] |
| Post subject: | crossmember |
Getting ready to put the Demon together. Noticed the transmission mount needed replacing. Got to thinking. |
| Author: | Rick Covalt [ Sat Apr 20, 2013 1:02 pm ] |
Quote: Will a 904 auto bolt in and line up to the crossmember that had the OD Manual
I think they are the same. But I have been wrong before.Rick |
| Author: | Greg Ondayko [ Sat Apr 20, 2013 1:27 pm ] |
Just Check your measurments from Bellhousing with manual trans to Mounting pad and then repeat this same bell to pad measurement also on the 904. Should be the same unless you are using a b/Ebody/ Truck trans in your car for some reason. Greg |
| Author: | slantzilla [ Sat Apr 20, 2013 1:59 pm ] |
Same crossmember, same mount. |
| Author: | wvenable [ Sat Apr 20, 2013 2:38 pm ] |
Thank you gents! |
