Can anyone spot what's wrong?
https://slantsix.org/forum/viewtopic.php?t=51785
Page 1 of 1
Author:  Otateral [ Sat Apr 20, 2013 9:35 pm ]
Post subject:  Can anyone spot what's wrong?
Trying to get the transmission linkage setup for my 69 valiant, A904 column shift. I'm not getting the full movement when I try to shift. Here's some pics:
Author:  Fopar [ Sat Apr 20, 2013 10:09 pm ]
In your 2nd picture that square block with the bolt is the adjustment for your linkage, move the lever to one limit and loosen the bolt slide the shaft or lever to its proper position.
Sounds more complex than it is, you will be putting both the shift lever and the transmision lever in the correct position so at one end you have park and at the other end 1st (low).
Richard
Author:  Otateral [ Sun Apr 28, 2013 2:38 pm ]
That worked great thanks
