| motor/ trans swap https://slantsix.org/forum/viewtopic.php?t=51821 |
| Author: | demoman3955 [ Tue Apr 23, 2013 4:04 pm ] |
| Post subject: | motor/ trans swap |
Well ive blown up one cylinder on my 69 valiant, and i found a freshly rebuilt motor pretty cheap, but its a 67, and the guy said i would have to get a new torque converter to make the motor to work with my 69s auto tranny. can anyone give me any insite to interchangeability?. ive done lots of v8 stuff, but not anything 6 related. |
| Author: | DusterIdiot [ Tue Apr 23, 2013 4:52 pm ] |
| Post subject: | Yep.. |
Quote: can anyone give me any insite to interchangeability?. ive done lots of v8 stuff, but not anything 6 related
This even applies to mopar's V-8's the crank pocket changed between 1967 and 1968... so when it comes to automatic transmissions( and assuming someone did not swap cranks during the rebuild):1) A pre-1968 engine bolts up to a pre-1968 transmission of the same family. 2) A 1968+ engine will bolt up to a pre-1968 transmission of the same family with an annular spacer in the crank pocket for the smaller pre-68 snout (Doc or Pat Blais has these). 3) A pre-1968 engine will not bolt to a 1968+ torque convertor unless you get a special torque made that has the pre-68 snout and the 1968+ guts (spline count and shaft size changed over the years as the 904 evolved). Or...you have the crank pocket reamed to be the larger 1968+ size and use the later torque convertor. Or...with the proper bearings and if within tolerance/spec, you can swap your crank into the early motor (pending it's the same displacement). Good luck, -D.Idiot |
| Author: | Charrlie_S [ Wed Apr 24, 2013 5:03 am ] |
| Post subject: | Re: Yep.. |
Quote: Quote: can anyone give me any insite to interchangeability?. ive done lots of v8 stuff, but not anything 6 related
This even applies to mopar's V-8's the crank pocket changed between 1967 and 1968... so when it comes to automatic transmissions( and assuming someone did not swap cranks during the rebuild):1) A pre-1968 engine bolts up to a pre-1968 transmission of the same family. 2) A 1968+ engine will bolt up to a pre-1968 transmission of the same family with an annular spacer in the crank pocket for the smaller pre-68 snout (Doc or Pat Blais has these). Quote:
Or put the early front pump, and input into the 68 trans (not recommended). I vote for converter, as you can them get the stall you want, at the same time.
Or...you have the crank pocket reamed to be the larger 1968+ size and use the later torque convertor. Or...with the proper bearings and if within tolerance/spec, you can swap your crank into the early motor (pending it's the same displacement). Quote: Good luck, -D.Idiot |
| Author: | demoman3955 [ Wed Apr 24, 2013 8:56 am ] |
| Post subject: | ok |
lets see if i have this correct. i need a spacer, and an early converter? or just the spacer. id rather not mess with cranks. i can also try finding a later motor, or rebuilding the original, but cost and time are not in my favor at the moment. thats also why im not droping in the fresh 360 i have . |
| Author: | DusterIdiot [ Wed Apr 24, 2013 12:32 pm ] |
| Post subject: | No. |
You need a custom convertor if you put the '67 into your '69...otherwise, be on the look out for a 1968-1987 engine... -D.Idiot |
| Author: | demoman3955 [ Wed Apr 24, 2013 6:10 pm ] |
| Post subject: | gotit, |
thanks for the time and info. now its time to search |
| Author: | ceej [ Fri Apr 26, 2013 10:34 pm ] |
To make it easy. Get a 1968 or later engine. Bolt it up, and go. If your going to rebuild anyway, which is a good idea with older engines, put the crank out of your engine in the early block if it's in good shape. What you really need is the 68+ crank. If you already bought the early engine, trade it to somebody for a later engine. Save yourself the money and the work! CJ |
| Author: | Otateral [ Sat Apr 27, 2013 11:42 am ] |
I just went through this with my 69 valiant. I got a custom torque converter from Hughes performance for about $300. Im not sure if you need to change to the early flexplate also. I did, just to be safe since they're cheap. |
