It is currently Wed Feb 12, 2025 6:50 pm
 Post subject: Head re-torque?
PostPosted: Wed Apr 24, 2013 3:58 pm
I'm using the newest felPro head gasket. Should I re-torque it after some miles?
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
 Post subject: Yes and no...
PostPosted: Wed Apr 24, 2013 4:05 pm
Per Fel-pro you are not supposed to, its a set and forget. Following Doc's advise and some others I have gone back through after a few heat cycles and checked the torque on the head bolts just to make sure they are all good (in one case I found 2 that needed a little more pull to get the click...but at least after that they were all even...)
PostPosted: Wed Apr 24, 2013 4:18 pm
I usally bring all to torque...wait a few minutes(drink a beer,have a smoke)...then run thru torque pattern and recheck....then drive it like you stole it
PostPosted: Wed Apr 24, 2013 9:23 pm
I like to re-torque after a few heat cycles and again at 500 miles when you do the valve lash.
Users browsing this forum: Bing [Bot], Google [Bot], Semrush [Bot] and 8 guests
