Slant Six Forum https://slantsix.org/forum/ |
Head re-torque? https://slantsix.org/forum/viewtopic.php?t=51831 |
Author: | 65CrewCabPW [ Wed Apr 24, 2013 3:58 pm ] |
Post subject: | Head re-torque? |
I'm using the newest felPro head gasket. Should I re-torque it after some miles? |
Author: | DusterIdiot [ Wed Apr 24, 2013 4:05 pm ] |
Post subject: | Yes and no... |
Per Fel-pro you are not supposed to, its a set and forget. Following Doc's advise and some others I have gone back through after a few heat cycles and checked the torque on the head bolts just to make sure they are all good (in one case I found 2 that needed a little more pull to get the click...but at least after that they were all even...) -D.Idiot |
Author: | hantayo13 [ Wed Apr 24, 2013 4:18 pm ] |
Post subject: | |
I usally bring all to torque...wait a few minutes(drink a beer,have a smoke)...then run thru torque pattern and recheck....then drive it like you stole it |
Author: | Aggressive Ted [ Wed Apr 24, 2013 9:23 pm ] |
Post subject: | |
I like to re-torque after a few heat cycles and again at 500 miles when you do the valve lash. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
