It is currently Mon Nov 16, 2026 1:03 pm
 Post subject: clutch disc
PostPosted: Fri Apr 26, 2013 2:15 pm
so i put my clutch disc in backwards. how bad is it. it seems to work fine. do i have to pull it back apart and turn it around?
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
 Post subject: Yep...
PostPosted: Fri Apr 26, 2013 2:40 pm
Yep, i did that once when I was a much younger buck, clutch engaged a few times but eventually it locked up and couldn't shift any more...had to pull and install a new disc (the right way), and things went back to normal.
D.Idiot
PostPosted: Fri Apr 26, 2013 3:17 pm
crap, ok. thanks man.
