Rocker arm jam nuts
https://slantsix.org/forum/viewtopic.php?t=51872
Author:  HyperValiant [ Sat Apr 27, 2013 8:03 am ]
Post subject:  Rocker arm jam nuts
I need to know what size half nut ya'll are using for your rocker arm adjusters.I have 3/8-24 but they seem way too tight.all help is welcome as I am tired of readjusting my valves every time I run over 5000 rpm.Thanks in advance. HyperValiant
Author:  sandy in BC [ Sat Apr 27, 2013 8:36 am ]
I use 3/8NF half nuts....
Author:  bwhitejr [ Sat Apr 27, 2013 12:02 pm ]
Post subject:  half nuts
I believe they are 40 threads to the inch.
Author:  sandy in BC [ Sat Apr 27, 2013 12:16 pm ]
3/8 UNF = 24 threads per inch
Author:  Dart270 [ Mon Apr 29, 2013 3:21 am ]
Yes, 3/8 - 24. They will be tight because the rocker screws are made to be tight. You can run a die over them if you really want them looser.
Author:  HyperValiant [ Mon Apr 29, 2013 10:22 am ]
Thanks fellas,now maybe I can keep a good lash on this engine.
I know that I should probably get shorter push rods but this is the last season for this engine and probably the last 170 Ill build for a while.
Thanks again
HyperValiant
