| Sure grip for 1966 7 1/4 rear https://slantsix.org/forum/viewtopic.php?t=51888 |
| Author: | lgu32 [ Sun Apr 28, 2013 6:47 am ] |
| Post subject: | Sure grip for 1966 7 1/4 rear |
I like to get limited slip fro my Dart and keep the small bolt circle wheels. Options are 8 3/4 which is expensive (here) and the 7 1/4 but I need a limited slip differential. Can I use a part for later Mopar and where I can order one. I have 3.55 gears which I like to keep there. |
| Author: | DusterIdiot [ Sun Apr 28, 2013 7:48 am ] |
| Post subject: | Yep... |
Yes you can use a 7 1/4" sure grip out of a later mopar, but you will be looking for a used SG unit regardless. They are hard to find nowadays, you would have to post to the parts wanted section and see if someone has a late-60's/early 70's unit they pulled from a spare rear-end. -D.Idiot |
| Author: | TonyPgh [ Fri May 03, 2013 7:06 pm ] |
I have a 1971 Valiant with a sure grip. It has 69k on it. I will be changing over to a larger rear, but not right away. I don't know how much in a rush you are in. |
