It is currently Tue Nov 17, 2026 5:09 pm
PostPosted: Sat Apr 20, 2013 9:35 pm
Trying to get the transmission linkage setup for my 69 valiant, A904 column shift. I'm not getting the full movement when I try to shift. Here's some pics:
69 Plymouth Valiant
PostPosted: Sat Apr 20, 2013 10:09 pm
6 Pack Dart
In your 2nd picture that square block with the bolt is the adjustment for your linkage, move the lever to one limit and loosen the bolt slide the shaft or lever to its proper position.
Sounds more complex than it is, you will be putting both the shift lever and the transmision lever in the correct position so at one end you have park and at the other end 1st (low).
Richard
PostPosted: Sun Apr 28, 2013 2:38 pm
That worked great thanks
69 Plymouth Valiant
Users browsing this forum: Amazon [Bot], Bing [Bot] and 2 guests
