| 3 spd bellhousing 4 spd w/od bell housing ? https://slantsix.org/forum/viewtopic.php?t=51894 |
| Author: | MOUSETRAP [ Sun Apr 28, 2013 6:31 pm ] |
| Post subject: | 3 spd bellhousing 4 spd w/od bell housing ? |
Mocking up t5 .. I have a od4spd bell housing its too deep for the t5 and a spacer would be worse .. is the aluminum 3spd housing shorter in length form engine surface to tranny face ???? ThNks |
| Author: | Joshie225 [ Sun Apr 28, 2013 6:56 pm ] |
Nope. Input shaft lengths are the same so the bell depth is the same. |
| Author: | DusterIdiot [ Sun Apr 28, 2013 7:11 pm ] |
| Post subject: | Too bad... |
Quote: I have a od4spd bell housing its too deep for the t5
If you had a 1968-1987 crankshaft installed you can install a dakota pilot bearing as the bearing sits in the crank pocket not the crankshaft itself...this would buy back about 1/2-3/4" of input shaft length to support it.Your sig shows a 1963, so that is TSOL unless you can have one machined up special for your application. -D.Idiot |
