| pressure plate spring retainers https://slantsix.org/forum/viewtopic.php?t=51934 |
| Author: | sandy in BC [ Thu May 02, 2013 2:30 pm ] |
For the price of a new PP and disc I would start over. If your clutch lets loose it can cause a lot of damage. |
| Author: | Junior [ Thu May 02, 2013 3:21 pm ] |
they Are Both Brand New, LessThan 100 Feet On Both Of Them. |
| Author: | sandy in BC [ Thu May 02, 2013 3:53 pm ] |
OK. But there are obviously things wrong here. If this was mine I would either start over or take the whole package to a driveline place and see what they can salvage. Im pretty big on do it yourself but a clutch that is even a little unbalanced will never work very well and likely chatter. Clutch chatter will wreck ujoints ,engine mounts , trans linkage, and any confidence you have in the car. Taking a pressure plate apart at home is a risky endeavour. When I first got the Valaint there were some chattering clutch issues. When I took it all apart the inside of the bell showed signs of a fairly significant clutch incident....pretty sobering. I replaced everything. |
| Author: | Junior [ Thu May 02, 2013 5:04 pm ] |
I guess A Better Question Would Be what Is The Purpose Of The Plugs? Sorry About The Caps My Phone Is Messing Up |
| Author: | Dart270 [ Fri May 03, 2013 6:05 am ] |
I don't see what is causing you concern. Those little discs? Were they there before and maybe you just noticed them? Please explain. Thanks, Lou |
| Author: | Junior [ Fri May 03, 2013 10:28 am ] |
the little pressed in weights or what ever you call them that go in the holes for the springs. one of them has come loose. can i just pop it in and call it a day? i dont know what they are supposed to do. and i just put a cam in so im gonna be flirting with the 5k shifts and i really like my legs. |
