| 1979 LU trans ? https://slantsix.org/forum/viewtopic.php?t=51941 |
Page 1 of 2 |
| Author: | slanty6 [ Fri May 03, 2013 8:58 am ] |
| Post subject: | 1979 LU trans ? |
Going to go look at a A904 trans this weekend. The old timer who has it told me it was out of a 1979 "Dart" with a slant six. I think he meant an Aspen. The input shaft has a smooth spot on the first 3/4 of an inch so I know it's LU. Is there such thing as a LU 904? Wouldn't this be a 998 or 999? If it's low mileage and comes with TC is $100 fair money ? |
| Author: | DusterIdiot [ Fri May 03, 2013 9:45 am ] |
| Post subject: | Yep.. |
Starting in the late 70's you could get a Lockup 904. $100 for a core is about the junkyard running rate for these now (so $100 for a good plug and play is really a deal). The other way to tell if LU, is you can pull the valve body and see if it has the 's' tube for the lock up circuit. I have seen some late 904's that the part number stamped on the pan rail coded to a lockup, but the valve body and convertor were not... Good luck. -D.Idiot |
| Author: | slanty6 [ Sat May 04, 2013 11:25 am ] |
I will be finding out shortly what he has.. fingers crossed.. |
| Author: | slanty6 [ Sun May 05, 2013 11:33 pm ] |
Seems like it is a low milegage unit that this guy removed many many years ago from a car that got t boned, he put it under his bench and there it has sat. It has the bare spot on the input shaft for the first 3/4" and the TC has a small round blue tag that says " HS lock- up ". So it seems legit. I will get part numbers off it tomorrow. I had to stuff it in the garage before the rains came in... |
| Author: | Rug_Trucker [ Mon May 06, 2013 7:51 am ] |
Nice score! |
| Author: | slanty6 [ Tue May 07, 2013 10:26 am ] |
do any of these parts numbers make sense to anyone ? 4130413 6527 2537 or 9B276337 thanks Dave |
| Author: | DusterIdiot [ Tue May 07, 2013 11:07 am ] |
| Post subject: | Yep... |
Quote: 4130413
That number stamped on the pan rail is the part number for a 1979 Lockup 904...what's inside could be different... -D.Idiot |
| Author: | slanty6 [ Tue May 07, 2013 11:20 am ] |
so the only way to identify it is to make sure it has the "s" tube inside of it ? cause it has the "correct" input shaft to be a lock up. |
| Author: | Fopar [ Tue May 07, 2013 11:33 am ] |
Way to simple to pull pan and look. Richard |
| Author: | WagonsRcool [ Tue May 07, 2013 11:54 am ] |
If the unit looks good & you want to use it, I'd look for a procedure to shim or tweak the LU control valve. Those early LU were completely mechanical (no electonic solenoids) & usually engaged about 30mph or so- which can cause driveabilty problems, esp cold. Raising the engage mph to 35-40 helps alot. |
| Author: | Reed [ Tue May 07, 2013 12:11 pm ] |
The early lockup transmissions, especially 79, were notorious for having torque converter premature lockup and shudder. Chrysler even went so far as to issue a kit to fix the problem. The kit consisted entirely of one spring that got swapped out on the valve body. On my brother's 83 van I was doing some diagnosing of what i thought might be a lockup shudder and I made a spaced that fit into the lockup spring tube on the valve body that completely disabled the lockup function. I would also pull the pan and valve body and make sure that there is a part throttle kickdown assembly. The last 79 904 I rebuilt did not have the PTK. |
| Author: | Doc [ Tue May 07, 2013 12:32 pm ] |
Install a Superior TF-TC Kit. DD Shift Kit Link |
| Author: | slanty6 [ Tue May 07, 2013 12:44 pm ] |
I will pull pan tomorrow to be sure. Thanks all of you for all your input !! |
| Author: | Reed [ Tue May 07, 2013 1:11 pm ] |
| Author: | mattelderca [ Tue May 07, 2013 2:43 pm ] |
See, I knew reading this forum would prove helpful!My 78 727 LU could do with raising the LU speed. Even behind a B block it still lugs in around town driving. I did have a shudder but a fluid change solved that. It really helps the fuel economy on the highway though, and around town I just got used to driving in second. |
| Page 1 of 2 | All times are UTC-08:00 |
