It is currently Mon Jun 15, 2026 1:48 am
PostPosted: Mon Apr 22, 2013 3:29 pm
what thickness should the hardened valve seats be? I bought Engine Builder 1.7 + 1.44 valves. He suggests 1.5 OD x 3/32 thick seats. The guy installing them thinks that seems thin. He usually uses 1/4 thick, but this is his first slant 6. I don't want to run into water jackets. How much metal is there to work with? What have other people used for seat sizes?
PostPosted: Sun May 05, 2013 8:54 pm
Car Model: 1964 Valiant V200
Use the thin ones. There is not much meat there. That's what my machinist used. Keep them small diameter too, I can't remember the dimension but it's a little smaller diameter than the exhaust valve is. I think 1 9/16 OD.
PostPosted: Mon May 06, 2013 8:53 am
Harden seats for exhaust valves only.
Use the thin 1 7/16 OD if your machinest has a valve "milling" machine to accuratly locate and install the seats.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 1 guest
