It is currently Wed Nov 18, 2026 10:54 am
 Post subject: 1979 LU trans ?
PostPosted: Fri May 03, 2013 8:58 am
Going to go look at a A904 trans this weekend. The old timer who has it told me it was out of a 1979 "Dart" with a slant six. I think he meant an Aspen. The input shaft has a smooth spot on the first 3/4 of an inch so I know it's LU. Is there such thing as a LU 904? Wouldn't this be a 998 or 999? If it's low mileage and comes with TC is $100 fair money ?
 Post subject: Yep..
PostPosted: Fri May 03, 2013 9:45 am
Starting in the late 70's you could get a Lockup 904. $100 for a core is about the junkyard running rate for these now (so $100 for a good plug and play is really a deal). The other way to tell if LU, is you can pull the valve body and see if it has the 's' tube for the lock up circuit. I have seen some late 904's that the part number stamped on the pan rail coded to a lockup, but the valve body and convertor were not...
Good luck.
PostPosted: Sat May 04, 2013 11:25 am
I will be finding out shortly what he has.. fingers crossed..
PostPosted: Sun May 05, 2013 11:33 pm
Seems like it is a low milegage unit that this guy removed many many years ago from a car that got t boned, he put it under his bench and there it has sat. It has the bare spot on the input shaft for the first 3/4" and the TC has a small round blue tag that says " HS lock- up ". So it seems legit. I will get part numbers off it tomorrow. I had to stuff it in the garage before the rains came in...
PostPosted: Mon May 06, 2013 7:51 am
Nice score!
PostPosted: Tue May 07, 2013 10:26 am
do any of these parts numbers make sense to anyone ?
4130413 6527 2537
or
9B276337 thanks Dave
 Post subject: Yep...
PostPosted: Tue May 07, 2013 11:07 am
That number stamped on the pan rail is the part number for a 1979 Lockup 904...what's inside could be different... :wink:
PostPosted: Tue May 07, 2013 11:20 am
so the only way to identify it is to make sure it has the "s" tube inside of it ? cause it has the "correct" input shaft to be a lock up.
PostPosted: Tue May 07, 2013 11:33 am
6 Pack Dart
Way to simple to pull pan and look.
Richard
PostPosted: Tue May 07, 2013 11:54 am
If the unit looks good & you want to use it, I'd look for a procedure to shim or tweak the LU control valve. Those early LU were completely mechanical (no electonic solenoids) & usually engaged about 30mph or so- which can cause driveabilty problems, esp cold. Raising the engage mph to 35-40 helps alot.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Tue May 07, 2013 12:11 pm
The early lockup transmissions, especially 79, were notorious for having torque converter premature lockup and shudder. Chrysler even went so far as to issue a kit to fix the problem. The kit consisted entirely of one spring that got swapped out on the valve body. On my brother's 83 van I was doing some diagnosing of what i thought might be a lockup shudder and I made a spaced that fit into the lockup spring tube on the valve body that completely disabled the lockup function.
I would also pull the pan and valve body and make sure that there is a part throttle kickdown assembly. The last 79 904 I rebuilt did not have the PTK.
PostPosted: Tue May 07, 2013 12:32 pm
Install a Superior TF-TC Kit.
Shift Kit Link
PostPosted: Tue May 07, 2013 12:44 pm
I will pull pan tomorrow to be sure. Thanks all of you for all your input !!
PostPosted: Tue May 07, 2013 1:11 pm
Shift Kit Link
+1,000,000
PostPosted: Tue May 07, 2013 2:43 pm
Shift Kit Link
See, I knew reading this forum would prove helpful!
My 78 727 LU could do with raising the LU speed. Even behind a B block it still lugs in around town driving. I did have a shudder but a fluid change solved that. It really helps the fuel economy on the highway though, and around town I just got used to driving in second.
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
