| do u see anything wrong? https://slantsix.org/forum/viewtopic.php?t=51991 |
| Author: | USAJon [ Tue May 07, 2013 12:17 pm ] |
| Post subject: | do u see anything wrong? |
bill local sold me this late model slant six, said he was spraying carb cleaner and over reved engine and the it ran but popped through the carb , he believed he bent a valve..i c not indications of a bent valve. pulled dist and the gear was OK, drained oil dirty but OK, found some very hard dark plastic pieces in the oil gallery in head and below the head. see pictures. http://imageshack.us/g/1/10138808/ |
| Author: | mattelderca [ Tue May 07, 2013 2:28 pm ] |
Maybe cam chain gear nylon teeth? Not sure how they might get up into the head though. Slipped timing gear might explain the popping. |
| Author: | Reed [ Tue May 07, 2013 3:10 pm ] |
Score on the late model chrome valve cover, truck pan/oil pickup, and truck motor mounts! Hard plastic bits in the valve cover to me suggests PCV valve pieces and/or old hardened valve stem seal material. Not much else up there.... |
| Author: | DusterIdiot [ Tue May 07, 2013 3:15 pm ] |
| Post subject: | X2 |
Quote: Hard plastic bits in the valve cover to me suggests PCV valve pieces and/or old hardened valve stem seal material. Not much else up there...
that would be my estimate as well.-D.Idiot |
