It is currently Fri Nov 20, 2026 12:28 am
PostPosted: Sun May 12, 2013 8:35 am
I changed my differential fluid and decided instead of buying a new rubber check plug and gasket that i would buy this chrome plated cover that has a threaded check plug and comes with a gasket and chrome plated bolts. Since it was only $26 + tax i think that it's a great deal!
Here's a link
It fits '61-'89 Chrysler cars & trucks with 8-1/4" ring gear
http://www.autozone.com/autozone/parts/ ... 810_19153_
I thought the differential gears looked like they were in good shape especially since that's probably the original axle...It would have been better had i taken the time to take the bed off and use a electric pressure washer to clean everything off good 1st but it worked out OK and so far no leaks
1984' Dodge D150 Utiline Bed
Slant 6 225, Holley 1920 Carb
A833 4 Speed O/D Transmission
PostPosted: Sun May 12, 2013 11:43 am
Sweet! :D
PostPosted: Sun May 12, 2013 11:55 am
I "think" mine has one of those but not as purdy. I'll check when I get home. Just wish that the factories would have got it right and put drain plugs in the bottoms like Toyota has been doing for years. Makes more sense, a drain and separate fill. But my yota didn't have sure grip :twisted:
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
PostPosted: Mon May 13, 2013 4:43 pm
Nice!
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
Users browsing this forum: DuckDuckGo [Bot] and 4 guests
