It is currently Fri Nov 20, 2026 12:10 am
 Post subject: Shift linkage help...
PostPosted: Tue May 07, 2013 8:39 am
How the heck do I get the shifter linkage out of the tranny or column? 904, column shift...
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
PostPosted: Tue May 07, 2013 10:00 am
Are you working with a "Cable Shift" 904 ?
PostPosted: Tue May 07, 2013 10:09 am
Yes. I am, I couldn't find the lock spring, I was messing around trying to get it for 15 minutes or so. Should I just pull it out as much as it goes and pretty well jam the screw driving around?
Thanks Doc,
Ryan
2002 Subaru OBS
PostPosted: Tue May 07, 2013 10:21 am
Yes...
Pull the cable out as far as possible and lift the wire "Spring Lock" to release the end of the cable(s).
Do not force or damage. Finding replacement cable(s) is hard.
PostPosted: Wed May 08, 2013 1:39 pm
You might try using a bright flashlight and looking into the hole to find the spring, then going back in with the screwdriver. I really like the lights with the battery separated from the light head by a flexible gooseneck. Like this one:
http://www.coastportland.com/tx8-led-in ... -light.htm
You can stick the light right up to what you're looking at and the battery section is not in your way. Isn't technology wonderful???
BC
PostPosted: Wed May 08, 2013 1:48 pm
how far into it are you? fluid drained?, because it is way easier with the pan off than poking around with a screw driver!
and if you have the pan off. Buy a New one with the drain plug in it! (I am kicking myself for not doing that)
1964 Dart GT
PostPosted: Wed May 08, 2013 2:03 pm
Thanks Danarchy, I actually have to take the pan off anyways to drain fluid, so I will just do that.
2002 Subaru OBS
