It is currently Fri Nov 20, 2026 8:05 am
PostPosted: Tue May 07, 2013 7:11 pm
Car Model: 87 B150, 1970 Valiant 4-door
Entertaining using 73+ front brakes, but want to retain center caps from original sbp 14" rims.
Will they fit lbp 14"s?
PostPosted: Tue May 07, 2013 7:19 pm
Yes! I have done this for many vehicles. I even run a set of 1960 Valiant caps on my 84 D150 with 15" rims. Of course it is always a good idea to check the rims first, but stock 14" steel rims should not be a prob.
. . . there was good sport at his making.
 Post subject: X2
PostPosted: Tue May 07, 2013 7:44 pm
14" to 14" is no problem, it's when you upgrade from a set of 13" rims to the 14/15" guys...
The only exception to the "rule" is Rallyes or through bolt centercaps, where you would have to get a set of SBP Cone centers, or LBP "Acorns" depending on the rallye.
PostPosted: Tue May 07, 2013 9:55 pm
I have ran the13" dog dish caps on 14/15" rims without any problem.
PostPosted: Wed May 08, 2013 10:20 am
thanks
