225 intake
https://slantsix.org/forum/viewtopic.php?t=52012
Author:  retroman63 [ Thu May 09, 2013 6:10 am ]
Post subject:  225 intake
I have a customer with an '85 D100 equipped with a slant 6 & single barrel carb. This is a 1 owner truck (nothing has been changed or altered). His intake casting reads 4100448-1. I ordered a used intake (also from an '85 D100) with same casting number except ends in -2 instead of -1. My customer (a reputable competent shop) says the exhaust ports don't line up (says they are 1/4" off). Any ideas? Which casting numbers are suitable for this application? Any help is appreciated! Thanks!
Author:  Danarchy [ Thu May 09, 2013 8:14 am ]
you replaced the intake and now the exhaust doesn't line up? :? but it lined up before? how long have the manifolds been off the truck? weeks, months, years? has it been running?
Author:  retroman63 [ Thu May 09, 2013 3:33 pm ]
Post subject:  225 manifold
The shop removed the original intake this week (truck was running and driving-complaint was cracked manifold). I do not know how long the used manifold ordered for a replacement had been off of a vehicle.
Author:  Reed [ Thu May 09, 2013 3:41 pm ]
I would verify that the shop followed the correct and somewhat picky slant six manifold installation procedure. See HERE.
Since the slant is a long inline engine, it is not uncommon for the exhaust manifolds to warp into a "smile." Can you give further detail about the manner in which the exhaust ports were 1/4 inch off?
Author:  Charrlie_S [ Fri May 10, 2013 4:57 am ]
Post subject:  Re: 225 manifold
Unusual to have a cracked intake (unless aluminum manifold). Cracked exhaust is common. Are you sure it was the intake that was changed? That casting number, you listed is for an exhaust manifold. A used exhaust manifold is a crap shoot. They need to be checked for warp before installing. Might be best to order a new replacement manifold.
