| Rebuilding a A903 in Houston, TX https://slantsix.org/forum/viewtopic.php?t=52015 |
| Author: | cpslntdchrg [ Thu May 09, 2013 1:53 pm ] |
| Post subject: | Rebuilding a A903 in Houston, TX |
Ok, I had some trouble with the transmission in my car, and a transmission shop fixed it. Unfortunately, it is leaking oil after the repair, but they said the oil comes from the breather hole in the top. I'm getting the stuff to monitor it and check about it myself, but in the meantime could somebody reccomend me a transmission shop in Houston, TX that can properly deal with such an old gearbox? Thanks! PD I know, a lot of people might be thinking "don't fix it, swap it" but I'll like to fix it/have it fixed (at least now) |
| Author: | cpslntdchrg [ Sat Jun 29, 2013 8:21 pm ] |
Update: I found no shop, so I will be doing some work by myself. Of course, also I noticed during this time the limitations on spare parts it has. I took the yoke out, it looks kinda worn. So questions: - Where can I find a output shaft tail bushing for a A903, 26 spline (b body) and the tool? Does anybody has at least the dimensions, so it can be machined in bronze? About the tool, I can buy it, or use it and send it back (thanks)... - Input Shaft front seal: Can it be installed without disassembling the whole thing. Do I need a special tool to install it? - Gaskets: any recommended fluid to wet the gaskets before installing (Kuryl T, or anything else) - Yoke: can it be resurfaced? Thanks for any help! PD: I also found a A230, but missing few parts: Yoke (26 spline) Gear shift levers (I've heard 903 ones can be used, extending them. I wont like to use the ones I have for that). Probably I would like to change the bushing too |
| Author: | cpslntdchrg [ Tue Jul 23, 2013 2:21 pm ] |
Update: I took the gearbox out of the car; opened, drained and cleaned it. It looked ok. Replaced seals, and tailshaft bushing. (Used the 26 spline Timken Seal PN 5207 from Autozone. It says it works for the 745, but rear yoke is the same size as the 903. Also a MOPAR part manual showed the same replacement part numbers). Bought a yoke too (small U-Joint), but I'm still waiting for it (looks like Mopar doesn't manufacture a lot of them lately). Sealed the transmission using Curil T (no paper), and filled it with oil... one leak... through the countershaft seat below the input shaft (ugh...not good, but hoping for the best, at least the gearbox was shifting ok). I'm planning sealing the countershaft with RTV silicone, and also glueing with RTV a thin, small steel plate covering the countershaft hole. (It should remain in place between the transmission and the bellhousing, as it looks like the bellhousing has some reinforcement that goes flush with the transmission at the countershaft area). Any suggestions? (besides bushings)... Now, it will be the first time I will reinstall back a transmission, and the manual warns about the need to aligning the input shaft splines with the clutch ones. Any recomendation? (I have not touched the clutch pedal since I removed the transmission, so things should be aligned in the clutch assembly) Nothiing like doing things yourself to know why stuff is acting (even if you don't like it, the input shaft bearing retainer design is ugly for sealing... oil can get trough the bolts easily). By the way, I agree now, the A903 is a small gearbox... (maybe too small) |
| Author: | cpslntdchrg [ Thu Apr 17, 2014 1:54 pm ] |
| Post subject: | Wrapping up this post |
Ok, I never updated this, let's wrap this up. Took the transmission to the shop that fixed it, they sealed it with some glue/filling at the countershaft(don't remember which one). Installed back the transmission, and leaked but less. Took it out and replaced the top cover gasket with a paper one (Initially sealed with Curil-T, not good because cover deformation/lack of rigidity). No leaks since, and it's working nicely ever since. Until the next time... |
