| Can someone identify this plate between starter and gearbox? https://slantsix.org/forum/viewtopic.php?t=52022 |
| Author: | olafla [ Thu May 09, 2013 9:40 pm ] |
| Post subject: | Can someone identify this plate between starter and gearbox? |
This steel plate/gasket between the starter and 904 auto seem to have an incorrect shape. Is it originally intended for another Mopar engine, and if so - which one? Olaf |
| Author: | DusterIdiot [ Thu May 09, 2013 9:57 pm ] |
| Post subject: | Lol... |
I have one of those...it's a remnant from my wild youth...it was the starter plate for a big block to 727....I think the small blocks to 727 are similar as well. Sure wrecked the crap out of that car.... Put down a couple of Fords doing it too.... -D.Idiot |
| Author: | olafla [ Fri May 10, 2013 7:56 am ] |
Hi DusterIdiot, thank you. You don't happen to have a picture of an original plate for a SL6/904? My other SL6 engine is kept elsewhere, and besides, that is a truck engine with an original 727. My V8s are also kept at the same location, but I don't remember any details about the plates on them. I assume that the plate should follow the outline of the gearbox. I have some stainless steel sheets, so I have already made a pattern for a new one, but I would like to have it confirmed. Olaf |
| Author: | Danarchy [ Fri May 10, 2013 10:04 am ] |
I have one on my Dart, and should be replacing the starter this weekend. I will snap a picture for you. |
| Author: | DusterIdiot [ Fri May 10, 2013 4:44 pm ] |
| Post subject: | Sorry... |
I packed all my spare plates away for storage so I won't be able to take a pic, hopefully Danarchy will get a good one. -D.Idiot |
| Author: | olafla [ Fri May 10, 2013 6:44 pm ] |
Thanks guys. Olaf |
| Author: | Danarchy [ Sat May 11, 2013 3:08 pm ] |
Not the best picture, but the plate covers all but a tiny spot that the starter does cover. Hope this helps.-Dan
| Author: | DusterIdiot [ Sat May 11, 2013 3:26 pm ] |
| Post subject: | X2 |
That looks correct for the /6 in the high starter position. |
| Author: | olafla [ Sun May 12, 2013 1:09 pm ] |
Thank you, Dan. That is how I envisioned it to be; just following the outline of the transmission. I'll start cutting into some fresh steel, and because it is for a mini-starter, I think I'll add the missing parts too, to make it cover all openings. I'll post a picture later, along with the finished pattern 1:1 so others can download it. Olaf |
