Budget burned exhaust valve
https://slantsix.org/forum/viewtopic.php?t=52087
Page 1 of 2
Author:  gl/6 [ Thu May 16, 2013 9:03 am ]
Post subject:  Budget burned exhaust valve
"OR",. My logic may need a overhaul? :oops:
I just pulled the head from my 65 dodge D100 due to burnt valves. It is a 225 slant six. The exhaust valves will need new valves. I estimate a reasonable price to replace at least one seat along with a valve grind will run me approximately 200.00. ( friendly local shop) This is, just a guess on my part only.
So with that in mind I thought about replacing it with a low mileage (70,000) head that already had the hardened seats.
I would likely do a lapping in of the valve for a economical cleanup.
I want to stay with my solid lifter setup.
So 4 questions for now.
What years should I look for?
I have tube heads so should I expect because I am going for a later model that they will all be the other non drool style?
Are there pittfals, such as larger "oil bolt" flow.?
What should I be sure to change over / to include with / purchase as I will be doing a "pick and pull.?
Author:  DusterIdiot [ Thu May 16, 2013 9:17 am ]
Post subject:  You can...
Man, if you were in my location you could pick through the head I have without the back break u-pull-it routine....
Hardened seats could be had on the 1973-1974 Drool Tube heads, and the 1975-1980 peanut plug heads...(1981-1987 peanut plug heads as well, but they have a different valve cover than what you are running).
Flow to he head is the same whether you use the large rear rocker shaft bolt (60's- mid-70's), or the small shank bolt (roughly 1978+)
Not much extra needed, just remove the alternator mount and bracket and manifold stack from the donor head, pull the head bolts and remove (if binding occurs on the lift, you may need to pull the pushrods (then replace the rocker shaft to use as a handle to pull the head off). I'd take the valve cover as a spare as well( or if a 1981-1987 hydraulic set up you will need the offset valve cover anyway). Note; if the donor head is a 1975+ "447" head it will have an exhaust port just past the #6 exhaust runner that will have a tube that goes either to the air cleaner or the air pump...snag the tube so you can cut and fold and close that port up.
Make sure to check the head for straightness before installing, if peanut plug you will need a set of NGK-UR-5's for it.
Good luck,
Author:  carlherrnstein [ Thu May 16, 2013 12:18 pm ]
Napa rebuilt my head for about $250 they hot tanked it resurfaced it, and put all new valves and valve seals in it.
Author:  DusterIdiot [ Thu May 16, 2013 12:31 pm ]
Post subject:  But..
You have an '85 so they could regrind the seats and if good at the job keep some of the hardening on the exhaust side...On his early head, he has none, and with a possible 30 years of driving on unleaded the he could have some other issues...For him he will have to add another $100 to install new hardened seats on the exhaust side for some insurance, but...being that it's a '65 he has the not so great 'dime spot' combustion chamber that he could now get rid of if he finds a 1968+ head. Also the machinist may break into water on the early head and new seats, so that also becomes a gamble. One other thing to note is valve guides...if the head is a high miler, it may need new guides, knurling can get you by, but the fix is 'temporary'...
Author:  gl/6 [ Thu May 16, 2013 4:57 pm ]
You guys are very helpful. I may not have mentioned I had the head pulled and noted the sunken exhaust valves. Because all six exhaust valves needed to be replaced and perhaps 4 new seats I became "price alert"
Like as in 340.00 + or -- ( :
So here is what I did. I went to my favorite pick and pull and purchased a head which was on a 1979 D100 225 with a rebuild stamp and very little exterior engine grime. Wow, I pulled the valve cover and wallah,!! I had a very low miles complete engine with matching head. Much newer, nicer, adjustable rocker assembly, with newer push rods and sweet looking color on the recent new valves.
I had a hard time not attempting to buy the block also.
I just purchased the head and all related components and I am ready to install Friday.
However one caviot,.. I shall be watching for suggestions / input from your forum participant's. I will listen and have already found much helpful. G
Author:  DusterIdiot [ Thu May 16, 2013 6:57 pm ]
Post subject:  Niiiice!!!
Good score! If you bought the late engine you'd need some adapting hardware to make it work in a '65 (crank spacer for an automatic, or a late flywheel for the manual tranny).
I'd suggest a Victor Reinz head gasket for choice instead of Fel-Pro as an over the counter brand of composite head gasket...
Author:  gl/6 [ Fri May 17, 2013 12:36 pm ]
Upon getting suggestions based on your experience, your trial and error, I have elected to inquire further and not be in a hurry to sew it up.
I have done a few slant 6 2 barrel manifold exchanges and I am familiar with the surprises. That does not mean I am an expert,!! LOL
Here is where I am on this particular tear down.
I took the manifolds intact as in one piece. It is still attached to the header pipe.
I took a straight edge to it and it "APPEARED" to be quite straight as a together pair.
(not scientificly applied, just visual. ( :
If clean it up for new gaskets and put it on,. torque it up and save myself the tear down into two pieces etc., ?
Also who makes the best exhaust/intake gaskets.? ( I will be doing victor as suggested earlier. )
More below,..
Yes I do have the sequence and washer info provided in tech herein. But still,.. what you all think about my putting it back together as a one piece manifold,? G
Author:  DusterIdiot [ Fri May 17, 2013 2:25 pm ]
Post subject:  Remflex...
The stock thin composite gaskets can be had any where, if you suspect you may have an issue with the mating surface of the head or manifolds being a little off then Remflex is the way to go...(a little spendy, but worth the peace of mind).
If you were local and didn't need the remflex variety I have about 8 of the thin composite type hanging on the wall...
:roll:
Author:  Fopar [ Fri May 17, 2013 3:47 pm ]
D.I. he said they were still together as one peice unit, he wants to know what is the best head to manifolds gasket to use.
Richard
Author:  gl/6 [ Fri May 17, 2013 4:42 pm ]
I could say it more clearly now that I have 90 percent answered. thanks, on additional gasket info.
OK,. So would you guys suggest I take them apart ,. do a realignment, and put the thin wafer (hot box) gasket in new.?
I admit am thinking lazy as the pair looks nicely lined up as it sits there as a one piece.
Author:  DusterIdiot [ Fri May 17, 2013 4:58 pm ]
Post subject:  Yep...and...
And my answer said Remflex for best fitment with any issues especially if the stack is warped, if the manifolds are "flat" (known good straight edge and no more than a .003-.006 feeler tape can pass under it) then he could use a standard composite shim style gasket...
Now hotbox gasket...that would then fall on GPRS Aussie gasket as the best gasket...if you have a warping issue or gap due to mismatched manifolds then reflex next, but ports may not line up due to the thickness of the reflex manifold (FYI).
If they are currently together and not leaking you might just leave them and plug them back on the head as a mated set...I also have had success in replacing the hotbox gasket assembling the stack, then having the machinist run the stack on his sanding table to even it all out...
:wink:
Author:  gl/6 [ Sat May 18, 2013 8:51 am ]
I am 76 years old and I am pretty sure I have a hitch in my getalong, so, based on opinions, logic, and liabilities I have decided to save time and $'s on gaskets.
By buying the single victor gasket for 30.00 vs the set for 70.00 I will save 40.00.
The labor time should be reduced by an hour or two by staying with mated pair. Thanks G.
Author:  gl/6 [ Sun May 19, 2013 7:52 am ]
The head I have from Pick a Part is a reconditioned low miles cylinder head is off a 1979 Dodge D100 and has a casting number of 4104362.
The donor truck I removed the head from already had the air cleaner, carb & intake removed. This removal has me wondering,... Maybe it was a super six.?
Hmm, I noted where the super six has larger exhaust valves.
So,.. that begs the question of,.. Does the casting number of 4104362 "exclude" the optional feature of larger super 6 valves.?,.. or did the factory also put the optional super 6 valves into this casting numbered head via machining for the super 6 upgrade ?
I am thinking in terms of original specs when I ask the above question.
PS I have a super 6 two barrel intake on my parts shelf and assume there is little benefit to make it part of my head replacement package without having the larger valves to benefit breathing regards to horsepower. G
Author:  DusterIdiot [ Sun May 19, 2013 10:25 am ]
Post subject:  No.
Super six heads are the same as regular heads, i have a couple and they have that standard size valves stock like their 1 barrel counter parts...it's the exhaust pipe that is larger.
The upgrade to the stock 2 barrel on a standard engine with the larger exhaust pipe does have measurable power gains but will be limited by the cam and drivetrain choices...plug and play it's maybe 10 hp and a few ft.lbs of torque...which if matched to a suitable vehicle build can change the shift points and might garner a little bit better gas mileage.
There are more benefits to adding more compression and a cam change to make the most out of the setup I know that I was able to get roughly 150 hp out of a 1979 slant six with super six and 350 cfm Holley carb, 2.25" tailpipe, 9.6:1 compression, aftermarket cam, stock head and valves.
Author:  gl/6 [ Sun May 19, 2013 10:42 am ]
Post subject:  Re: No.
#### Whoops,! Re: Larger Valves,=======> I need new glasses. I re- read the article. ! My bad. Thanks for the comeback. G
Page 1 of 2 All times are UTC-08:00
