| removing output shaft flange nut https://slantsix.org/forum/viewtopic.php?t=52093 |
| Author: | hideogumperjr [ Thu May 16, 2013 11:23 am ] |
| Post subject: | removing output shaft flange nut |
Hi guys, more questions for 904 disassembly. I am trying to remove the tail shaft but for my 63 which uses the trunnion there is a flange which needs to be removed. I have a 1 1/16" socket which is too small for the nut. Can anyone confirm the size of the nut, 1 1/8" or 1 3/16"? Also the service manual refers to a funky tool, C-3381, to hold the flange so it does not rotate. Looks like I can use some angle iron with a couple of holes drilled in it to hold the flange to prevent rotation. Anyone had to confront this? Thanks folks. |
| Author: | hideogumperjr [ Thu May 16, 2013 11:49 am ] |
Forgot to include the picture. http://www.myfigtree.com/flangnut1.jpg |
| Author: | lancer61 [ Fri May 17, 2013 5:18 am ] |
Yeah, I just did as you said, a piece of scrap metal with two holes, worked fine. |
| Author: | hideogumperjr [ Fri May 17, 2013 8:38 am ] |
Thanks Lancer, do you remember the socket size? 1 1/8"11? John |
| Author: | Fopar [ Fri May 17, 2013 12:36 pm ] |
I measured the nut on 3 speed manual it is 1 1/8" Richard |
| Author: | hideogumperjr [ Fri May 17, 2013 1:21 pm ] |
Thanks a bunch fopar! |
