| What is this part? https://slantsix.org/forum/viewtopic.php?t=52160 |
| Author: | DusterIdiot [ Thu May 23, 2013 7:42 am ] |
| Post subject: | Vr |
That's the voltage regulator, you'll need to replace it as it affects your charging circuit (best case scenario your battery doesn't charge, worst case scenario the field goes wide and you burn up the wiring and boil the battery as the alternator provides max output to everything). -D.Idiot |
| Author: | nagosnell [ Thu May 23, 2013 8:19 am ] |
Once again, thanks for the help. Luckily, it appears that this part is easily available at most auto parts stores. |
| Author: | Danarchy [ Thu May 23, 2013 10:13 am ] |
semi-related thread. http://www.slantsix.org/forum/viewtopic.php?t=52101 |
