Spec clutch "saga" comes to a conclusion.
https://slantsix.org/forum/viewtopic.php?t=52187
Author:  Old6rodder [ Sun May 26, 2013 10:31 pm ]
Post subject:  Spec clutch "saga" comes to a conclusion.
Well Kiddies, I finally have the final on my Spec clutch "project". :?
I've had the thing working well enough for my 1400 lb HAMBster, but still not up to their claims for it. My latest disassembly (mostly to take up some slop in my "floater" conversion) proved the most revealing. Once again I took'er down to individual parts, and noticed, now that there's enough wear to produce a pattern, that the pressure plate's face is worn more on one side than the other. Curiosity being one of my albatroses, I looked into why.
Further critical inspection noted that the contact ring/point with the diaphragm was irregular. Well, something like that certainly might produce the wear pattern I saw. Onto the granite table it went, and out came the gauges.
Didn't take long to verify that the diaphragm contact point was short vertically by .094" on the side over the unworn part of the face. Spec (or their jobber?) had milled the damn back at a slight angle to the face, rather than parallel.
I have no idea whether this is an anomoly, or a production problem (and thus the cause of other folks' Spec problems as well), but I decided (my damn Hoosier bone headedness) to rectify it myself. I see no sense in taking something back to where it was done wrong in the first place.
About an hour spent on the granite, with a large flat file and height gauge, and the back was properly parallel with the face.
So back into the car it went, and lo & behold, it's easily twice the clutch it was just yesterday. Gee ...... what a shock. :roll:
Anyway, I thought I'd pass along the info. A pressure plate only pressing on one side doesn't make for much of a clutch, Spec's or anyone's.
Author:  sandy in BC [ Mon May 27, 2013 6:51 am ]
WOW!
Author:  Dart270 [ Mon May 27, 2013 6:52 am ]
Wow, this looks quite exciting! I will have a talk with Matt at Spec about this. I am about to send my two units back to him for inspection and possible credit or upgrades.
Slant on, brother...
Author:  wvenable [ Mon May 27, 2013 7:05 am ]
Another Hooiser Bone Head. That's good to know!
Author:  DusterIdiot [ Mon May 27, 2013 8:10 am ]
Post subject:  Hmmm...
I'll have to pull my two pressure plates and see if that is the case with mine.
I know that my stage 2 pressure plate after removing it, the diaphragm fingers were no longer 'even' all the way around I sent it back for them to inspect and they said it was trashed...
Interesting.
-D.idiot
Author:  Greg Ondayko [ Tue May 28, 2013 4:26 am ]
Good to Know,
Thanks for Posting.
I think for now I will stick with my mcLeod parts.
they might be tricky to get, but at least they are are machined flat!
