It is currently Fri Nov 20, 2026 1:17 pm
PostPosted: Tue Apr 30, 2013 9:49 am
engine/trans came out of a pickup but may not b original.
has anyone seen this b4?
http://img62.imageshack.us/img62/8091/transrear002.jpg
slant six's RULE!
http://www.usajon.com
PostPosted: Tue Apr 30, 2013 2:42 pm
What year truck? Could it be a lock up 727?? There is a write up on the Allpar site that will help identify it if it is. I have a lock up 727 in my 78 NYB, confirmed and working. They were apparently availble behind some \6's.
What do the slanted experts say, are they desirable? Do they work well behind a slant?
Mattelderca
78 NYB (gone now), two S series, three old Snow Cruisers and a Doo.
PostPosted: Tue Apr 30, 2013 4:28 pm
That decal means "high stall lockup". All lockup converters have damper springs inside. The color of the decal is the same as the damper springs. The color indicates the engine application.
Blue= 225 CID
White=318CID
Red=360 and 400 engine
Green and Orange= non lockup
PostPosted: Tue Apr 30, 2013 4:51 pm
Charlie ur the man.. is it worth anything beyond selling with the trans ?
slant six's RULE!
PostPosted: Tue Apr 30, 2013 6:28 pm
I would say, no. It is just a stock lockup converter . High stall in this case, only means about 200-300 rpm higher then a low stall. It must be used with a lockup trans.
 Post subject: HS lockup picture
PostPosted: Tue May 28, 2013 4:38 pm
My brother has an 87 1/2 ton from the city of St Paul that has a slant with 727
