What kind of e-distributor? HEI converting - 63 Dart
https://slantsix.org/forum/viewtopic.php?t=52231
Page 1 of 1
Author:  Eatkinson [ Fri May 31, 2013 10:07 am ]
Post subject:  What kind of e-distributor? HEI converting - 63 Dart
I'm gathering all the parts for my HEI conversion on my 63 Dart 225 rebuild. Aren't there two different kind of MoPar OEM distributors, one that will work in my block, and one that won't?
Can I choose just any Chrysler electronic distributor, or do I need to look for a specific model for my year of vehicle/block?
Author:  Reed [ Fri May 31, 2013 10:23 am ]
Any 72 to mid-80s non-lean burn electronic ignition distributor for a slant six will work. You will want to try and match the application to your vehicle to get the timing advance curve correct, though.
Author:  DusterIdiot [ Fri May 31, 2013 11:13 am ]
Post subject:  Correction
V-8's got the EI in 1972 Slants followed in 1973...so don't ask for a 1972 /6 distributor you'll get a points model...Lean burn/ESC distributors are a 1980-1987 item but are common candidates in anything in a junkyard since most guys didn't know they don't have advance weights...
If going NOS/OEM, I triage cores by the following for light cars like yours (or for any car for that matter:
1st choice: 1977-1980 super six PN:3874876
2nd choices: 1976-1977 PN: 3874714
3rd choice: 1976 PN:3874598
Last choices: Truck or Van distributors, 1973-1974 Distributor: 3755042,3755037/38, 1975: 387082
Cardone reman PN 36-3690 will get you a russian roulette distributor with a governor and springs from any year at random, no lube in the assembly, and you get a generic 10x vacc. adv. pod...you get no choice of springs or governor no matter what "year/car" you give the counter guy...
Author:  Eatkinson [ Fri May 31, 2013 11:36 am ]
Thanks, that helps. I asked because I thought certain e-distributors actually would not physically align against the cam correctly: something about the correct e-distributor for a short block vs. long block, though when I think about it, that doesn't make any sense. Wonder what that was about....
Author:  DusterIdiot [ Fri May 31, 2013 11:42 am ]
Post subject:  ???
I've never had that problem, although there are different types of clamps or brackets that can limit how much advance you can dial into it because of the slots...
Author:  carlherrnstein [ Fri May 31, 2013 12:22 pm ]
I found this a while back I have know idea how well it works http://home.comcast.net/~loudgpz/GPZweb ... oints.html
Author:  Reed [ Fri May 31, 2013 5:20 pm ]
Post subject:  Re: Correction
V-8's got the EI in 1972 Slants followed in 1973...so don't ask for a 1972 /6 distributor you'll get a points model-D.Idiot
Crap, sorry. I always get that mixed up. That and the 68 crank hub diameter change.
Author:  DusterIdiot [ Fri May 31, 2013 8:25 pm ]
Post subject:  Wink
No problem, I got ya covered! :wink:
At least it's not:
1967 Master Cylinder Change
1974/1975/1976 A-body wiring harness changes
1974/1975-1976 Seat Belt changes
1973/1974+ Bumper Bracket Changes
:roll:
Author:  64ragtop [ Sun Jun 02, 2013 8:10 pm ]
Interesting, but it only takes the load off the points not eliminates them.
BC
