Electronic Ignition Distributor
https://slantsix.org/forum/viewtopic.php?t=52237
Page 1 of 1
Author:  64DartGT [ Sat Jun 01, 2013 6:16 am ]
Post subject:  Electronic Ignition Distributor
Uploaded with ImageShack.us
Is this a useable electronic distributor, can the part be swapped to a slant points distributor and work? :D
Author:  DusterIdiot [ Sat Jun 01, 2013 8:35 am ]
Post subject:  Nope..
Notice that it has no moveable pickup plate and no vacuum advance or mechanisms...this is a 1981-1987 ESC distributor....unless you are going to EFI and using the PROM to affect timing or racing with a static timing setting, this will not work for you...Nothing interchanges with the EI distributor except maybe the reluctor...the EI parts from an EI distributor can't be readily transplanted to a points distributor unless it's a 1972 points body (that year they changed the body and mainshaft to be like the 1973-1980 EI distributors).
Author:  64DartGT [ Sat Jun 01, 2013 10:06 am ]
Thanks DI, just curious about it. Guess I have no use for it then......
Author:  87D100 [ Sat Jul 13, 2013 12:24 pm ]
It also appears to be an 8 cylinder distributor.....
