steel crank in 77 block
https://slantsix.org/forum/viewtopic.php?t=52273
Author:  chucksrodgarage [ Tue Jun 04, 2013 6:10 pm ]
Post subject:  steel crank in 77 block
i spun a bearing in my 77 block with a cast crank. also damaged the crank journal on number 1..
i have a nice standard steel crank and rods here. will that crank and rods fit the 77 truck block o.k.?
i would like to run the steel crank as it has a lot wider bearing surface on the rods.
Author:  DusterIdiot [ Tue Jun 04, 2013 6:35 pm ]
Post subject:  Forged Crank
You will need a forged crank 225/198 block 1960's-1976 to run the other crank...probably find a good running motor for less than reconditioning the cast crank motor.
Author:  chucksrodgarage [ Wed Jun 05, 2013 4:13 pm ]
just got back from the machine shop,as the steel crank mains just came in. after looking everything over, it seems that everything matches up good except the number three main flanges being wider than the journal casting and rod cap. . looks like it will be as simple as making a couple spacers to take up the difference.
he said he could make some extras if anyone would be interested in these. the steel crank is a much stronger, (and heavier) unit, and who wouldn't want another 25% of bearing surface
Author:  DusterIdiot [ Wed Jun 05, 2013 4:29 pm ]
Post subject:  But...
If using in a truck sure, daily driving no problem...
Performance engine where the crank already weighs 10-15 lbs less than the forged counter part and you don't have to cut and rebalance...maybe. Sure does recover rpms' faster between shifts that's for sure.
Since #3 is the thrust bearing, I take it you are using an automatic, I'd be a little wary of using spacers in that position in a clutch driven vehicle.
Author:  chucksrodgarage [ Wed Jun 05, 2013 6:21 pm ]
no, this is in my 41 plymouth street rod. running an a833 od 4 speed.
not planning on any racing, but i do like to run it through the paces once in a while. the engine was to be making close to 300 hp. neverb dynoed.
only had 1500 miles on it when i spun #1 ROD BEARING FOR SOME REASON. haven't had it over 6000 rpm .
why do you say it may be a concern with the manual trans."? as the spacer will just be filling the gap between the thrust surface, and the main journal. the engine builder is very reputable, and has been around all types of race and pulling engines.
Author:  DusterIdiot [ Wed Jun 05, 2013 6:57 pm ]
Post subject:  Thrust!
The thrust bearing takes a beating everytime you engage and disengage the clutch (not so much with the torque convertor), the assembly literally pushes the crank into the thrust bearing (luckily it's coated with oil). I've always been told to make sure to have a crank with a tight spec on the thrust measurement on assembly with clutch equipped vehicles, it give the crank less room to walk and beat up the bearing...the typical "goal posts" are .002 to .007...so far I've seen the typical forged crank in over 100K miler manual tranny equipped 225's in the middle .004/.005...I have one that is "virgin" at .002 that is in my 12:1 motor, unfortunately no clutch has survived the 6000 rpm process, everything else is still good (opened it up and regasketed it a few months back during the experimental clutch upgrade).
The logic would be, after a fair amount of 'spirited' or daily driving, the bearing may allow the spacer to get beat up as part of the collision and then tolerances may allow it to fall out or the bearing walks and spins, unless he's fastening the spacers to the block/girdle with set screws like a plate.
I'll be interested in seeing what is installed, and how it fairs in the long run.
On thing you'll notice on the heavier crank is the synchros take a smidge longer to lineup with the wide ratios over the lighter crank, and if running the clock up the cast crank engine will get the revs up a bit quicker, but with the extra weight (assuming you were not using a stock truck flywheel already as they are heavier) the car will launch harder.
:wink:
Author:  chucksrodgarage [ Wed Jun 05, 2013 9:08 pm ]
he was talking an aluminum spacer,and a couple small roll pins to secure it. i'm thinking a little harder material myself.
did you say that clutches don't survive 6000 rpm?, or 6000 rpm launches?
Author:  DusterIdiot [ Thu Jun 06, 2013 7:40 am ]
Post subject:  Yep...
Yeah, steel would have been my first choice, I don't see the aluminum being a good choice being softer (even though it expands a fair bit when heated).
My vehicle is a special case, I'm throwing more weight than the typical racer(street vehicle), I have to launch and shift at higher RPM with the A-833OD to keep the engine in the hyperpak sweet spot due to the wide ratio rpm drop (that means 5500-6000rpm)...So far everything works fine for daily driving, but I've already lunched 1 Zoom! clutch and 3 Spec Clutches, all had less than 10-12 launches on them (Lou is now working on them fixing a pressure plate issue - I'm working on using a slant/V-8 11" clutch instead). They don't survive 6000 rpm launches.
Author:  chucksrodgarage [ Thu Jun 06, 2013 11:03 am ]
yes, i've heard nothing good about the spec clutches. i am in the orocess of upgrading my clutch too at this time while everything is out of the car. when i built it, i put in a 9 1/4" clutch just because i had it. but since the new motor, i found out that i have more motor than i do clutch. so i am stepping up to the truck 10" clutch, plus i found out that my flywheel wasn't machined square when i had it resurfaced. it was high on one side. hoping that with that taken care of, and the larger clutch, it will help a lot. again, not a race car, but i do like tire smoke.
Author:  chucksrodgarage [ Sat Jul 06, 2013 8:09 pm ]
got engine back together and in the car. running sweet. the spacers seem to be working real good. running 50# oil preassure at idle, and throughout rpm range.
no real noticable reving problems due to the heavier steel crank
Author:  DusterIdiot [ Sat Jul 06, 2013 9:14 pm ]
Post subject:  Pics?
Did you get pics of the assembly?
You won't notice by feel unless you had one of each engine to run back to back, it will show up at the drag strip between shifts if you had another engine to run in a similar vehicle especially on the 1-2 and the 2-3 shift.
Author:  chucksrodgarage [ Sun Jul 07, 2013 6:29 am ]
no, i didn't give it a thought to take pics. really not much to photograph.
just two round steel spacers, the proper thickness for correct thrust, cut in half. they fit into the radius recess of the block and main cap before the bearing goes in place. they can't go anywhere as they are captured there.
he had to do a little something on the rear bearing too as it didn't center in the block and cap. no big deal. i never have figured how to post pics on this site anyways.
now there is an idea, two different engines in the car. one for cruising, and one for race.
only 100 miles on it right now, but all seems good.
