| 1974 duster on the road again https://slantsix.org/forum/viewtopic.php?t=52277 |
| Author: | 1974duster [ Tue Jun 04, 2013 10:57 pm ] |
| Post subject: | 1974 duster on the road again |
Hey guys I am working on my duster front in. I have rebuilt the front in but my pivot shaft nut is striped on there and I can get it off any ideas would be great. |
| Author: | 1974duster [ Wed Jun 05, 2013 10:05 am ] |
Basicly I can't get the nut off the pivot shaft |
| Author: | DadTruck [ Wed Jun 05, 2013 4:51 pm ] |
Quote: can't get the nut off the pivot shaft
it may be just me,, but I have no idea what a pivot shaft is in relation to the front suspension,,, maybe I know it by a different name...can you post a photo or give another description..when you say stripped, do you mean the flats on the nut are rounded off,, if so and you can get to it: 1) try a pipe wrench 2) try heating the nut with a torch then try the pipe wrench again 3) get a nut splitter or cut through the side of the nut with a dremmel obviously being careful to not get into the shaft... anyway a bit more info from you may help.. good luck |
| Author: | Fopar [ Wed Jun 05, 2013 5:27 pm ] |
If you can get over to my place maybe you could point out the part you are talking about. send me a PM and I will give you my phone #. Richard |
| Author: | DusterIdiot [ Wed Jun 05, 2013 6:03 pm ] |
| Post subject: | Lol... |
On a Duster Suspension it could only be the Lower Control Arm pivot stud (it'd be bad if the rubber gave out and the nut was seized...), or it could be the idler arm bolt (have to sneak a box end wrench under the front of the oil pan to hold the head of the bolt). -D.Idiot |
| Author: | 1974duster [ Wed Jun 05, 2013 9:30 pm ] |
It is the pivot srud that goes into the lower control arm bushing. I have the car completely apart right now just have the nut that will keep on turning and never come off I might try drillibg it tomorrow. |
| Author: | kesteb [ Wed Jun 05, 2013 10:51 pm ] |
Do you have the torsion bar out? Try putting it back in and see if the nut turns. It it still does, try tighting up the the torsion bar adjuster bolt, to but some tension on the bushing. Otherwise you can always try a nut breaker. |
| Author: | 1974duster [ Thu Jun 06, 2013 12:16 pm ] |
I final got it off thanks for the help guys |
| Author: | DadTruck [ Fri Jun 07, 2013 7:50 pm ] |
glad it worked out,,, nice to hear that another A body is road worthy,, take pride in that,, I do |
| Author: | 1974duster [ Wed Jun 12, 2013 9:12 pm ] |
does anyone have a lower control that i could have it seem mine wont go back in at all. |
| Author: | DadTruck [ Thu Jun 13, 2013 6:29 am ] |
Quote: lower control
I see those in the mechanical for sale section over on fabo more often than here on the forum,,but shouldn't figure out why the one you have won't go back in,, before you get another one? |
| Author: | 1974duster [ Thu Jun 13, 2013 3:53 pm ] |
i am moving in a week so i need the part asap |
| Author: | 1974duster [ Thu Jun 13, 2013 5:58 pm ] |
does anyone know anything about this lower control arms http://www.jegs.com/i/QA1/122/52307/100 ... Id=2793311 |
