2 questions about 5 bolt Melling oil pump
https://slantsix.org/forum/viewtopic.php?t=52284
Page 1 of 1
Author:  Eatkinson [ Thu Jun 06, 2013 1:17 am ]
Post subject:  2 questions about 5 bolt Melling oil pump
I bought one of these to replace my 6-bolt OEM pump on my 225. Looks pretty decent. Here's a couple questions:
1. Have read a post or two on here from people who bought this pump only to get a leak from under the non-drilled boss #6. How prevalent is this problem? Or is it a non-issue for most?
2. Going to replace the softer Melling drive gear with the original cast gear from the OEM pump i'm chucking. Noticed the new Melling drive gear has what looks like a keyway where the original has none. I was going to have my machinist swap them out. Should i be concerned about this at all or should i anticipate pushback from my guy?
Thanks all.
Author:  Eatkinson [ Thu Jun 06, 2013 9:42 pm ]
Anyone? Bueller?
Author:  DusterIdiot [ Thu Jun 06, 2013 10:00 pm ]
Post subject:  Well...
It's a non issue, I have used them even on cast crank motors where that "pocket" didn't exist... the real issue is the gasket, if you line up the casting pattern on the block or pump and lay the gasket over it you may find that the gasket isn't lined up properly with the boundary "rib".
See Doc's pic here:http://www.slantsix.org/forum/viewtopic ... t=oil+pump
Yep, they come in two varieties, keyed and non keyed, if you are using a keyed pump, you need a keyed gear...or vice versa. You might get away with putting the non keyed gear on the keyed shaft without the key, but I'd worry if the gear warmed up and the interference fit got loose and failed to turn the pump shaft...
-D.idiot
[/quote]
Author:  Eatkinson [ Thu Jun 06, 2013 11:45 pm ]
Post subject:  Re: Well...
Yep, they come in two varieties, keyed and non keyed, if you are using a keyed pump, you need a keyed gear...or vice versa...
-D.idiot
Seriously?? The new Mellings come in two different designs? Why would they do that?? I can't decide what's easier: a new Mellings or trying to find a hardened keyed gear to use....
Author:  Fopar [ Thu Jun 06, 2013 11:58 pm ]
Check with "Doc" or "doctor dodge" he had some of those hardened gears both keyed and non-keyed.
Richard
Author:  DusterIdiot [ Fri Jun 07, 2013 7:24 am ]
Post subject:  Yep...
It's called outsourced parts...
I have a Melling High Volume that was keyed, along with a couple of "stockers" that way, the other M66C pumps are not keyed. Doc used to have each type of hardened gear.
Author:  jhdeval [ Fri Jun 07, 2013 8:57 am ]
I have an extra oil pump with the hardened gear. I do not know if it is keyed or not and it needs a good cleaning. Should work well.
Author:  jhdeval [ Fri Jun 07, 2013 4:19 pm ]
Here is the oil pump I am talking about. I have a second one but I have not pulled it off the motor yet.
Inside
Outside
Author:  robertob [ Thu Jun 13, 2013 9:44 pm ]
Check the clearances inside the pump, many times they are fine.
Author:  DusterIdiot [ Thu Jun 13, 2013 9:55 pm ]
Post subject:  90% of the time...
Out of a pile of stock pumps I had, I had to trash 2 of them...most were on the loose side of the clearance checks...oddly enough, one you disassemble them (if you had a bucket of them saved up), you can actually part together quite a few pumps back into tolerance from the left overs (assuming they all have the same style of rotor assembly).
:lol:
Author:  robertob [ Fri Jun 14, 2013 6:50 am ]
I've never had enough that I could build better but it makes sense...
Guess it depends on how often the engine had its oil/filter changed over the years whether they are good or not.
