| Sealed Power Pistons https://slantsix.org/forum/viewtopic.php?t=52303 |
| Author: | RyGuyTooDry [ Sat Jun 08, 2013 12:15 pm ] |
| Post subject: | Sealed Power Pistons |
Anyone know if these will hold boost? Probably around 15 lbs, strip only car. |
| Author: | RyGuyTooDry [ Sun Jun 09, 2013 8:48 pm ] |
Noone? I'm about to buy them and don't really want to make a big mistake... |
| Author: | Ssg Pohlman [ Mon Jun 10, 2013 12:18 pm ] |
I've done an extensive FAQ in the boost section that has plenty of builds to reference. More than one build was done w stock pistons, shaker comes to mind running like 20+ psi. Unless you just want new I'd go w stock as we know they work but that's me and I'm about to use an hx35 |
| Author: | Dart270 [ Thu Jun 13, 2013 6:22 am ] |
Stock 1989 silvolite 3.43" cast pistons on my 9-10 psi build (330 HP so far). 170k on motor. Lou |
| Author: | terrylittlejohn [ Fri Jun 14, 2013 7:09 pm ] |
I have seal power np244 .080, 12 to 15 psi with meth injection, 20degs timing no problems, set them up loose. called for .001 clearance, I set it at .005, top ring at .024 , second ring .018 |
