It is currently Mon Nov 30, 2026 1:44 pm
PostPosted: Thu Jun 06, 2013 12:20 pm
I recently decided to try and fill the leaks in the radiator on my 78 aspen with JB. It has always leaked around the lower hose so I ordered new hoses, got a new stant cap, drained the system, and pumped any remaining fluid out of the bottom. After plugging up an areas with the JB and letting it dry I reassembled it all, flushed and cleaned it. It seemed to work great for a couple weeks but now it just leaks worse than ever. Around all hose connections (not at the hose but where the outlet meets the header) and around the fins.
So I'm in the market for a new radiator. I'm skeptical of getting them on Ebay but rock auto has ones in my price range. Are those brands satifactory, is there a difference between the AC and no AC ones other than the size and hoses?
Are There any other components I should replace while I'm at it? I'm guessing a new CCEGR valve if i can find one. I'm thinking of putting in longer hoses going to the heater core to make it easier to remove the valve cover.
1978 4 door Dodge Aspen, Super Six
 Post subject: Ugh...
PostPosted: Thu Jun 06, 2013 12:46 pm
You can't JB Weld a 70's radiator, it has to be soldered (JB weld is epoxy and it will just crack when heated and cooled repeatedly and it doesn't etch into the source metal either). I had Mac's fix a 22" radiator I had in my hpak duster and had them reinforce the bottom hose connection, I think I paid a whole $97 for them to do it...a full recore costs as much as a new radiator. If your car has a fan shroud you will want to keep the replacement the same size as the original. There is nothing special between the varying sizes other than capacity and a change in hoses. The vacuum switch for the EGR system on the radiator should be OK and not need replacing unless you have cracked it or broken the hose connections off it.
Spectra is the same brand you'll get at Autozone (and most other places), looks like the HD radiator CU525 is $13 cheaper ordering it at the local Autozone instead of Rockauto this time.
PostPosted: Thu Jun 06, 2013 1:32 pm
On some years (A-bodies?- don't know about Aspen/Volare) the A/C radiators had wider cores than the non-A/C units- & different size openings in the rad support to match.
I put an A/C rad in my 68 Dart but had to cut the rad support opening wider.
63 Valiant Wagon
225 - 4 bbl
 Post subject: Darn
PostPosted: Thu Jun 06, 2013 1:53 pm
I followed some bad advice that taking it to a shop would be as expensive as a replacement and this was my attempt at prolonging the life of it for cheap. Although, when I testd my CCEGR valve a month ago the whole connection came off the radiator and I JBed that and it still holds, although the 'weld' is slowly melting down.
That sounds like a good option. I'll try to get some of the jb weld off and I'll be taking it to Mac's this weekend since they've got saturday hours in Beaverton.
Good to know.
DusterIdiot, again, thanks a lot for the advice.
 Post subject: 1973+
PostPosted: Thu Jun 06, 2013 2:09 pm
The late cars(1973+) are easy to figure out, normal duty gets the 19" wide core and the upper hose is a straight 90 from the T-stat housing to the radiator hose connection. The HD cars and those with A/C get the 22" core and the upper hose is the type that has a slight angle to it from the Tstat housing to the offset radiator hose connection. I have a 26" radiator out of an F-body I scavenged a while back that will fit the 1973-1976 A-body support hole and mounts, but doesn't leave much room for a proper overflow bottle (the brackets are about 2"wide off the ends of the core for the support bolts).
There are aftermarket changes and lots of "shuffling" in the 60's due to lots of variety in engines that you have 18" cores, 21" cores, V-8 cores, big block V-8, etc and those aren't as easy to get matched up right...
PostPosted: Thu Jun 06, 2013 7:48 pm
http://slantsix.org/forum/viewtopic.php ... n+radiator
that worked out for me. so far no problems.
70 Plymouth Valiant 4dr
PostPosted: Sat Jun 08, 2013 8:04 am
Many Ford radiators have almost identical size to the F/M/J-body rads, some dealers also market them as Ford/Mopar radiators, and then they are often priced lower than Mopar only rads... :roll:
I would also recommend that you ask for a price for reconditioning of the original radiator, then you know that quality US materials will be used. Some new aftermarket radiators from 'overseas' may have inferior, lower priced alloys used in the production.
I bought an ordinary 18" radiator at ebay company acellaauto for my Aspen, it is a Silla made in the Phillipines, seems OK so far, but take a look at this message in a Dodge forum: http://dodgeforum.com/forum/1824677-post8.html
Olaf.
Aspenized
PostPosted: Sun Jun 09, 2013 12:48 pm
Mac's said a run of the mill repair would be $78, $25 inspection fee waived if work is done. I know that it leaks around both hose connections, the EGR switch is totally detached and I said it may leak other places and he said it was fine, included in that price. I recommended Mac's as well. The customer service at their Beaverton, OR location was great. That location also has Saturday hours which helps me out.
 Post subject: Good Deal!
PostPosted: Sun Jun 09, 2013 12:52 pm
:D
PostPosted: Tue Jun 11, 2013 3:47 am
I've soldered older brass and copper radiators to repair leaks and seams and connections..............
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 3 guests
