It is currently Fri Nov 20, 2026 12:14 pm
PostPosted: Tue May 27, 2014 9:20 pm
OK, so I read today that one can tell the pinion spline count on an 8.75 rearend by simply measuring the pinion nut. If it's 1 1/8" then it's a 10 spline pinion, if it's 1 1/4 or 1 5/16 then it's a 29 spline pinion shaft. I suppose I might have to remove the drive shaft to actually measure the nut, it's pretty tight space otherwise.
How tight do I make the cap bolts when I put them back on?
brian
 Post subject: torque
PostPosted: Wed May 28, 2014 6:38 am
Denny's drive shaft has the answers. For 7260 straps, it's 15-18 Lb-ft
